wrong types
wrong types
Postby Gummiklokke » Fri Jan 28, 2011 5:38 pm
I'm running my Subsonic on a Qnap-TS459 Pro.
No problem with install but...
I'm from Denmark and we use æ ø å and i have a lot of tracks with those letters.. but they are alle like this:
01 - Den nye l��rer
05 - Plage��nder
15 - Sp��rg om hj��lp
And i cant play them..
What to do??
4.3 (build 2078) – January 7, 2011
Apache Tomcat/6.0.20, java 1.6.0_22, Linux (37.3 MB / 59.4 MB)
Gummiklokke
Postby stozher » Fri Jan 28, 2011 6:00 pm
/etc/default/locale
# File generated by update-locale
LANG="en_US.utf8"
LANGUAGE="en_US.utf8"
LC_CTYPE="en_US.utf8"
LC_PAPER="bg_BG.utf8"
LC_NAME="bg_BG.utf8"
LC_ADDRESS="bg_BG.utf8"
LC_TELEPHONE="bg_BG.utf8"
LC_MEASUREMENT="bg_BG.utf8"
Check available locales with command "locale -a" in terminal window...
stozher
Postby Gummiklokke » Sat Jan 29, 2011 3:18 pm
I cant find /etc/default/locale on my Qnap Nas..
Gummiklokke
Postby stozher » Sat Jan 29, 2011 3:41 pm
You need to add locales to QNAP if not appears. Chechk existing with
locale -a
Add to "tomcat.sh"
QPKG_NAME=Tomcat
PUBLIC_SHARE=`/sbin/getcfg SHARE_DEF defPublic -d Public -f /etc/config/def_share.info`
export LANG="en_US.utf8"
export LANGUAGE="en_US.utf8"
export LC_CTYPE="en_US.utf8"
Read also this theme: http://forum.subsonic.org/forum/viewtopic.php?t=4989
EDIT: Other workaround... transliterate this letters to plain English only in filenames (don't touch tags).
stozher
Postby Gummiklokke » Mon Jan 31, 2011 11:10 am
Thx..
But i have now another problem..
Install is fine (on my Qnap-NAS TS459 pro+) but each time i restart ill get this message in Tomcat:
FAIL - Application at context path /subsonic could not be started
I have inserted this in my tomcat.sh
### Create Subsonic link in /var
cd /var
ln -s /share/HDA_DATA/subsonic /var/subsonic
### End of Subconic link creation
And the link is working..
Do you know this??
Gummiklokke
Postby stozher » Mon Jan 31, 2011 11:44 am
Where is your real subsonic server files?
PP: Post your "tomcat.sh"...
stozher
Postby Gummiklokke » Mon Jan 31, 2011 1:00 pm
It's @ /share/MD0_DATA/subsonic
#!/bin/sh
# /etc/init.d/tomcat6 -- startup script for the Tomcat 6 servlet engine
# Written by Miquel van Smoorenburg <miquels@cistron.nl>.
# Modified for Debian GNU/Linux by Ian Murdock <imurdock@gnu.ai.mit.edu>.
# Modified for Tomcat by Stefan Gybas <sgybas@debian.org>.
# Modified for Tomcat6 by Thierry Carrez <thierry.carrez@ubuntu.com>.
### BEGIN INIT INFO
# Provides: tomcat
# Required-Start: $local_fs $remote_fs $network
# Required-Stop: $local_fs $remote_fs $network
# Should-Start: $named
# Should-Stop: $named
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start Tomcat.
# Description: Start the Tomcat servlet engine.
### END INIT INFO
cd /var
ln -s /share/MD0_DATA/subsonic /var/subsonic
set -e
PATH=/bin:/usr/bin:/sbin:/usr/sbin
NAME=tomcat
DESC="Tomcat servlet engine"
DAEMON=/usr/bin/jsvc
CATALINA_BASE=/usr/local/$NAME
DEFAULT=/etc/default/$NAME
JVM_TMP=/tmp/tomcat-temp
JRE_HOME=/usr/local/jre
QPKG_DIR=""
QPKG_NAME=Tomcat
JRE_ENABLED=`/sbin/getcfg JRE Enable -u -d FALSE -f /etc/config/qpkg.conf`
if [ "$JRE_ENABLED" = "TURE" ]; then
echo "Java Runtime Environment needs to be installed and enabled."
exit 1
fi
TOMCAT_USER_EXISTS="`grep -n tomcat /etc/passwd`"
if [ "x${TOMCAT_USER_EXISTS}" = "x" ]; then
/bin/adduser -DH tomcat 1>/dev/null 2>/dev/null
fi
if [ `id -u` -ne 0 ]; then
echo "You need root privileges to run this script"
exit 1
fi
export JAVA_HOME=$JRE_HOME
export JAVA_OPTS="-Xmx256m"
# Determine BASE installation location
find_base(){
publicdir=`/sbin/getcfg $PUBLIC_SHARE path -f /etc/config/smb.conf`
if [ ! -z $publicdir ] && [ -d $publicdir ];then
publicdirp1=`/bin/echo $publicdir | /bin/cut -d "/" -f 2`
publicdirp2=`/bin/echo $publicdir | /bin/cut -d "/" -f 3`
publicdirp3=`/bin/echo $publicdir | /bin/cut -d "/" -f 4`
if [ ! -z $publicdirp1 ] && [ ! -z $publicdirp2 ] && [ ! -z $publicdirp3 ]; then
[ -d "/${publicdirp1}/${publicdirp2}/${PUBLIC_SHARE}" ] && QPKG_BASE="/${publicdirp1}/${publicdirp2}"
fi
fi
# Determine BASE installation location by checking where the Public folder is.
if [ -z $QPKG_BASE ]; then
for datadirtest in /share/HDA_DATA /share/HDB_DATA /share/HDC_DATA /share/HDD_DATA /share/MD0_DATA /share/MD1_DATA; do
[ -d $datadirtest/$PUBLIC_SHARE ] && QPKG_BASE="/${publicdirp1}/${publicdirp2}"
done
fi
if [ -z $QPKG_BASE ] ; then
echo "The Public share not found."
_exit 1
fi
QPKG_DIR="${QPKG_BASE}/.qpkg/${QPKG_NAME}"
create_links() {
/bin/echo "Creating sym-links ..."
[ -f /usr/local/tomcat ] || /bin/ln -sf "${QPKG_DIR}/tomcat" /usr/local/
[ -f /etc/tomcat ] || /bin/ln -sf "${QPKG_DIR}/tomcat/conf" /etc/tomcat
[ -f /usr/sbin/start-stop-daemon ] || /bin/ln -sf "${QPKG_DIR}/sbin/start-stop-daemon" /usr/sbin
[ -f /usr/bin/jsvc ] || /bin/ln -sf "${QPKG_DIR}/bin/jsvc" /usr/bin
find_base
create_links
# Run Tomcat 6 as this user ID
TOMCAT_USER=tomcat
# Directory for per-instance configuration files and webapps
CATALINA_HOME=/usr/local/tomcat
# Use the Java security manager? (yes/no)
TOMCAT6_SECURITY=no
if [ ! -f "$CATALINA_HOME/bin/bootstrap.jar" ]; then
echo "$NAME is not installed"
exit 1
fi
if [ ! -f "$DAEMON" ]; then
$/bin/echo "missing $DAEMON"
exit 1
fi
POLICY_CACHE="$CATALINA_BASE/work/catalina.policy"
JAVA_OPTS="$JAVA_OPTS -Djava.endorsed.dirs=$CATALINA_HOME/endorsed -Dcatalina.base=$CATALINA_BASE -Dcatalina.home=$CATALINA_HOME -Djava.io.tmpdir=$JVM_TMP"
if [ "$TOMCAT6_SECURITY" = "yes" ]; then
JAVA_OPTS="$JAVA_OPTS -Djava.security.manager -Djava.security.policy=$POLICY_CACHE"
fi
# Set juli LogManager if logging.properties is provided
if [ -r "$CATALINA_BASE"/conf/logging.properties ]; then
JAVA_OPTS="$JAVA_OPTS "-Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager" "-Djava.util.logging.config.file="$CATALINA_BASE/conf/logging.properties"
fi
# Define other required variables
CATALINA_PID="/var/run/$NAME.pid"
BOOTSTRAP_CLASS=org.apache.catalina.startup.Bootstrap
JSVC_CLASSPATH="/usr/share/java/commons-daemon.jar:$CATALINA_HOME/bin/bootstrap.jar"
case "$1" in
start)
if [ -z "$JRE_HOME" ]; then
$/bin/echo "no JRE found - please set JRE_HOME"
exit 1
fi
if [ ! -d "$CATALINA_BASE/conf" ]; then
$/bin/echo "invalid CATALINA_BASE: $CATALINA_BASE"
exit 1
fi
/bin/echo "Starting $DESC" "$NAME"
if "${QPKG_DIR}/sbin/start-stop-daemon" --test --start --pidfile "$CATALINA_PID" \
--user $TOMCAT_USER --startas "$JRE_HOME/bin/java" \
/dev/null; then
# Regenerate POLICY_CACHE file
umask 022
echo "// AUTO-GENERATED FILE from /etc/tomcat/policy.d/" \
> "$POLICY_CACHE"
echo "" >> "$POLICY_CACHE"
cat $CATALINA_BASE/conf/policy.d/*.policy \
>> "$POLICY_CACHE"
# Remove / recreate JVM_TMP directory
rm -rf "$JVM_TMP"
mkdir "$JVM_TMP" || {
$/bin/echo "could not create JVM temporary directory"
exit 1
chown -R $TOMCAT_USER.$TOMCAT_USER /usr/local/tomcat/*
chown $TOMCAT_USER "$JVM_TMP"
cd "$JVM_TMP"
$DAEMON -user "$TOMCAT_USER" -cp "$JSVC_CLASSPATH" \
-outfile SYSLOG -errfile SYSLOG \
-pidfile "$CATALINA_PID" $JAVA_OPTS "$BOOTSTRAP_CLASS"
sleep 5
>/dev/null; then
/bin/echo "...failed"
else
/bin/echo "...successful"
fi
else
/bin/echo "(already running)"
/bin/echo 0
fi
stop)
/bin/echo "Stopping $DESC" "$NAME"
--user "$TOMCAT_USER" --startas "$JRE_HOME/bin/java" \
>/dev/null; then
/bin/echo "(not running)"
else
$DAEMON -cp "$JSVC_CLASSPATH" -pidfile "$CATALINA_PID" \
-stop "$BOOTSTRAP_CLASS"
fi
rm -rf "$JVM_TMP"
/bin/echo 0
status)
>/dev/null; then
if [ -f "$CATALINA_PID" ]; then
/bin/echo "$DESC is not running, but pid file exists."
exit 1
else
/bin/echo "$DESC is not running."
exit 3
fi
else
/bin/echo "$DESC is running with pid `cat $CATALINA_PID`"
fi
restart|force-reload)
if "${QPKG_DIR}/sbin/start-stop-daemon" --test --stop --pidfile "$CATALINA_PID" \
>/dev/null; then
$0 stop
sleep 1
fi
$0 start
try-restart)
>/dev/null; then
$0 start
fi
/bin/echo "Usage: $0 {start|stop|restart|try-restart|force-reload|status}"
exit 1
esac
exit 0
Gummiklokke
Postby stozher » Mon Jan 31, 2011 9:03 pm
This error isn't from "tomcat.sh" script. Post "/etc/default/tomcat". :roll:
PP: Where is a "subsonic.war" file? Post folder....
stozher
Postby Gummiklokke » Tue Feb 01, 2011 12:02 pm
Dont have /etc/default/tomcat (im on a qnap ts-459 PRO nas)
The .war is here : /share/MD0_DATA/.qpkg/Tomcat/tomcat/webapps
I get the following error in tomcat manager when i try to strat Subsonic:
This is Web.xml from /share/MD0_DATA/.qpkg/Tomcat/tomcat/conf:
<?xml version="1.0" encoding="ISO-8859-1"?>
Licensed to the Apache Software Foundation (ASF) under one or more
contributor license agreements. See the NOTICE file distributed with
this work for additional information regarding copyright ownership.
The ASF licenses this file to You under the Apache License, Version 2.0
(the "License"); you may not use this file except in compliance with
the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<web-app xmlns="http://java.sun.com/xml/ns/javaee"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd"
version="2.5">
<!-- ======================== Introduction ============================== -->
<!-- This document defines default values for *all* web applications -->
<!-- loaded into this instance of Tomcat. As each application is -->
<!-- deployed, this file is processed, followed by the -->
<!-- "/WEB-INF/web.xml" deployment descriptor from your own -->
<!-- applications. -->
<!-- WARNING: Do not configure application-specific resources here! -->
<!-- They should go in the "/WEB-INF/web.xml" file in your application. -->
<!-- ================== Built In Servlet Definitions ==================== -->
<!-- The default servlet for all web applications, that serves static -->
<!-- resources. It processes all requests that are not mapped to other -->
<!-- servlets with servlet mappings (defined either here or in your own -->
<!-- web.xml file. This servlet supports the following initialization -->
<!-- parameters (default values are in square brackets): -->
<!-- debug Debugging detail level for messages logged -->
<!-- by this servlet. [0] -->
<!-- fileEncoding Encoding to be used to read static resources -->
<!-- [platform default] -->
<!-- input Input buffer size (in bytes) when reading -->
<!-- resources to be served. [2048] -->
<!-- listings Should directory listings be produced if there -->
<!-- is no welcome file in this directory? [false] -->
<!-- WARNING: Listings for directories with many -->
<!-- entries can be slow and may consume -->
<!-- significant proportions of server resources. -->
<!-- output Output buffer size (in bytes) when writing -->
<!-- readonly Is this context "read only", so HTTP -->
<!-- commands like PUT and DELETE are -->
<!-- rejected? [true] -->
<!-- readmeFile File name to display with the directory -->
<!-- contents. [null] -->
<!-- sendfileSize If the connector used supports sendfile, this -->
<!-- represents the minimal file size in KB for -->
<!-- which sendfile will be used. Use a negative -->
<!-- value to always disable sendfile. [48] -->
<!-- useAcceptRanges Should the Accept-Ranges header be included -->
<!-- in responses where appropriate? [true] -->
<!-- For directory listing customization. Checks localXsltFile, then -->
<!-- globalXsltFile, then defaults to original behavior. -->
<!-- localXsltFile Make directory listings an XML doc and -->
<!-- pass the result to this style sheet residing -->
<!-- in that directory. This overrides -->
<!-- globalXsltFile[null] -->
<!-- globalXsltFile Site wide configuration version of -->
<!-- localXsltFile This argument is expected -->
<!-- to be a physical file. [null] -->
<servlet>
<servlet-name>default</servlet-name>
<servlet-class>org.apache.catalina.servlets.DefaultServlet</servlet-class>
<init-param>
<param-name>debug</param-name>
<param-value>0</param-value>
</init-param>
<init-param>
<param-name>listings</param-name>
<param-value>false</param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<!-- This servlet has been deprecated due to security concerns. Servlets -->
<!-- should be explicitly mapped in web.xml -->
<!-- The "invoker" servlet, which executes anonymous servlet classes -->
<!-- that have not been defined in a web.xml file. Traditionally, this -->
<!-- servlet is mapped to the URL pattern "/servlet/*", but you can map -->
<!-- it to other patterns as well. The extra path info portion of such a -->
<!-- request must be the fully qualified class name of a Java class that -->
<!-- implements Servlet (or extends HttpServlet), or the servlet name -->
<!-- of an existing servlet definition. This servlet supports the -->
<!-- following initialization parameters (default values are in square -->
<!-- brackets): -->
<servlet>
<servlet-name>invoker</servlet-name>
<servlet-class>
org.apache.catalina.servlets.InvokerServlet
</servlet-class>
<init-param>
</init-param>
<load-on-startup>2</load-on-startup>
</servlet>
<!-- The JSP page compiler and execution servlet, which is the mechanism -->
<!-- used by Tomcat to support JSP pages. Traditionally, this servlet -->
<!-- is mapped to the URL pattern "*.jsp". This servlet supports the -->
<!-- brackets): -->
<!-- checkInterval If development is false and checkInterval is -->
<!-- greater than zero, background compilations are -->
<!-- enabled. checkInterval is the time in seconds -->
<!-- between checks to see if a JSP page (and its -->
<!-- dependent files) needs to be recompiled. [0] -->
<!-- classdebuginfo Should the class file be compiled with -->
<!-- debugging information? [true] -->
<!-- classpath What class path should I use while compiling -->
<!-- generated servlets? [Created dynamically -->
<!-- based on the current web application] -->
<!-- compiler Which compiler Ant should use to compile JSP -->
<!-- pages. See the jasper documentation for more -->
<!-- information. -->
<!-- compilerSourceVM Compiler source VM -->
<!-- default is System.properties -->
<!-- java.specification.version > 1.4 -->
<!-- [1.5] else [1.4] -->
<!-- compilerTargetVM Compiler target VM -->
<!-- development Is Jasper used in development mode? If true, -->
<!-- the frequency at which JSPs are checked for -->
<!-- modification may be specified via the -->
<!-- modificationTestInterval parameter. [true] -->
<!-- displaySourceFragment -->
<!-- Should a source fragment be included in -->
<!-- exception messages? [true] -->
<!-- dumpSmap Should the SMAP info for JSR45 debugging be -->
<!-- dumped to a file? [false] -->
<!-- False if suppressSmap is true -->
<!-- enablePooling Determines whether tag handler pooling is -->
<!-- enabled. This is a compilation option. It will -->
<!-- not alter the behaviour of JSPs that have -->
<!-- already been compiled. [true] -->
<!-- engineOptionsClass Allows specifying the Options class used to -->
<!-- configure Jasper. If not present, the default -->
<!-- EmbeddedServletOptions will be used. -->
<!-- errorOnUseBeanInvalidClassAttribute -->
<!-- Should Jasper issue an error when the value of -->
<!-- the class attribute in an useBean action is -->
<!-- not a valid bean class? [true] -->
<!-- fork Tell Ant to fork compiles of JSP pages so that -->
<!-- a separate JVM is used for JSP page compiles -->
<!-- from the one Tomcat is running in. [true] -->
<!-- genStrAsCharArray Should text strings be generated as char -->
<!-- arrays, to improve performance in some cases? -->
<!-- [false] -->
<!-- ieClassId The class-id value to be sent to Internet -->
<!-- Explorer when using <jsp:plugin> tags. -->
<!-- [clsid:8AD9C840-044E-11D1-B3E9-00805F499D93] -->
<!-- javaEncoding Java file encoding to use for generating java -->
<!-- source files. [UTF8] -->
<!-- keepgenerated Should we keep the generated Java source code -->
<!-- for each page instead of deleting it? [true] -->
<!-- mappedfile Should we generate static content with one -->
<!-- print statement per input line, to ease -->
<!-- debugging? [true] -->
<!-- modificationTestInterval -->
<!-- Causes a JSP (and its dependent files) to not -->
<!-- be checked for modification during the -->
<!-- specified time interval (in seconds) from the -->
<!-- last time the JSP was checked for -->
<!-- modification. A value of 0 will cause the JSP -->
<!-- to be checked on every access. -->
<!-- Used in development mode only. [4] -->
<!-- scratchdir What scratch directory should we use when -->
<!-- compiling JSP pages? [default work directory -->
<!-- for the current web application] -->
<!-- suppressSmap Should the generation of SMAP info for JSR45 -->
<!-- debugging be suppressed? [false] -->
<!-- trimSpaces Should white spaces in template text between -->
<!-- actions or directives be trimmed? [false] -->
<!-- xpoweredBy Determines whether X-Powered-By response -->
<!-- header is added by generated servlet [false] -->
<!-- If you wish to use Jikes to compile JSP pages: -->
<!-- Please see the "Using Jikes" section of the Jasper-HowTo -->
<!-- page in the Tomcat documentation. -->
<servlet>
<servlet-name>jsp</servlet-name>
<servlet-class>org.apache.jasper.servlet.JspServlet</servlet-class>
<init-param>
<param-name>fork</param-name>
</init-param>
<init-param>
<param-name>xpoweredBy</param-name>
</init-param>
<load-on-startup>3</load-on-startup>
</servlet>
<!-- NOTE: An SSI Filter is also available as an alternative SSI -->
<!-- implementation. Use either the Servlet or the Filter but NOT both. -->
<!-- Server Side Includes processing servlet, which processes SSI -->
<!-- directives in HTML pages consistent with similar support in web -->
<!-- servers like Apache. Traditionally, this servlet is mapped to the -->
<!-- URL pattern "*.shtml". This servlet supports the following -->
<!-- initialization parameters (default values are in square brackets): -->
<!-- buffered Should output from this servlet be buffered? -->
<!-- (0=false, 1=true) [0] -->
<!-- expires The number of seconds before a page with SSI -->
<!-- directives will expire. [No default] -->
<!-- isVirtualWebappRelative -->
<!-- Should "virtual" paths be interpreted as -->
<!-- relative to the context root, instead of -->
<!-- the server root? (0=false, 1=true) [0] -->
<!-- inputEncoding The encoding to assume for SSI resources if -->
<!-- one is not available from the resource. -->
<!-- [Platform default] -->
<!-- outputEncoding The encoding to use for the page that results -->
<!-- from the SSI processing. [UTF-8] -->
<servlet>
<servlet-name>ssi</servlet-name>
<servlet-class>
org.apache.catalina.ssi.SSIServlet
</servlet-class>
<init-param>
<param-name>buffered</param-name>
<param-value>1</param-value>
</init-param>
<init-param>
</init-param>
<init-param>
<param-name>expires</param-name>
<param-value>666</param-value>
</init-param>
<init-param>
<param-name>isVirtualWebappRelative</param-name>
</init-param>
<load-on-startup>4</load-on-startup>
</servlet>
<!-- Common Gateway Includes (CGI) processing servlet, which supports -->
<!-- execution of external applications that conform to the CGI spec -->
<!-- requirements. Typically, this servlet is mapped to the URL pattern -->
<!-- "/cgi-bin/*", which means that any CGI applications that are -->
<!-- executed must be present within the web application. This servlet -->
<!-- supports the following initialization parameters (default values -->
<!-- are in square brackets): -->
<!-- cgiPathPrefix The CGI search path will start at -->
<!-- webAppRootDir + File.separator + this prefix. -->
<!-- [WEB-INF/cgi] -->
<!-- executable Name of the exectuable used to run the -->
<!-- script. [perl] -->
<!-- parameterEncoding Name of parameter encoding to be used with -->
<!-- CGI servlet. -->
<!-- [System.getProperty("file.encoding","UTF-8")] -->
<!-- passShellEnvironment Should the shell environment variables (if -->
<!-- any) be passed to the CGI script? [false] -->
<servlet>
<servlet-name>cgi</servlet-name>
<servlet-class>org.apache.catalina.servlets.CGIServlet</servlet-class>
<init-param>
</init-param>
<init-param>
<param-name>cgiPathPrefix</param-name>
<param-value>WEB-INF/cgi</param-value>
</init-param>
<load-on-startup>5</load-on-startup>
</servlet>
<!-- ================ Built In Servlet Mappings ========================= -->
<!-- The servlet mappings for the built in servlets defined above. Note -->
<!-- that, by default, the CGI and SSI servlets are *not* mapped. You -->
<!-- must uncomment these mappings (or add them to your application's own -->
<!-- web.xml deployment descriptor) to enable these services -->
<!-- The mapping for the default servlet -->
<servlet-mapping>
<url-pattern>/</url-pattern>
</servlet-mapping>
<!-- The mapping for the deprecated invoker servlet -->
<servlet-mapping>
<url-pattern>/servlet/*</url-pattern>
</servlet-mapping>
<!-- The mapping for the JSP servlet -->
<servlet-mapping>
<url-pattern>*.jsp</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>*.jspx</url-pattern>
</servlet-mapping>
<!-- The mapping for the SSI servlet -->
<servlet-mapping>
<url-pattern>*.shtml</url-pattern>
</servlet-mapping>
<!-- The mapping for the CGI Gateway servlet -->
<servlet-mapping>
<url-pattern>/cgi-bin/*</url-pattern>
</servlet-mapping>
<!-- ================== Built In Filter Definitions ===================== -->
<!-- NOTE: An SSI Servlet is also available as an alternative SSI -->
<!-- Server Side Includes processing filter, which processes SSI -->
<!-- servers like Apache. Traditionally, this filter is mapped to the -->
<!-- URL pattern "*.shtml", though it can be mapped to "*" as it will -->
<!-- selectively enable/disable SSI processing based on mime types. For -->
<!-- this to work you will need to uncomment the .shtml mime type -->
<!-- definition towards the bottom of this file. -->
<!-- The contentType init param allows you to apply SSI processing to JSP -->
<!-- pages, javascript, or any other content you wish. This filter -->
<!-- supports the following initialization parameters (default values are -->
<!-- in square brackets): -->
<!-- contentType A regex pattern that must be matched before -->
<!-- SSI processing is applied. -->
<!-- [text/x-server-parsed-html(;.*)?] -->
<filter>
<filter-name>ssi</filter-name>
<filter-class>
org.apache.catalina.ssi.SSIFilter
</filter-class>
<init-param>
<param-name>contentType</param-name>
<param-value>text/x-server-parsed-html(;.*)?</param-value>
</init-param>
<init-param>
</init-param>
<init-param>
</init-param>
<init-param>
</init-param>
</filter>
<!-- ==================== Built In Filter Mappings ====================== -->
<!-- The mapping for the SSI Filter -->
<filter-mapping>
</filter-mapping>
<!-- ==================== Default Session Configuration ================= -->
<!-- You can set the default session timeout (in minutes) for all newly -->
<!-- created sessions by modifying the value below. -->
<session-config>
<session-timeout>30</session-timeout>
</session-config>
<!-- ===================== Default MIME Type Mappings =================== -->
<!-- When serving static resources, Tomcat will automatically generate -->
<!-- a "Content-Type" header based on the resource's filename extension, -->
<!-- based on these mappings. Additional mappings can be added here (to -->
<!-- apply to all web applications), or in your own application's web.xml -->
<!-- deployment descriptor. -->
<mime-mapping>
<extension>abs</extension>
<mime-type>audio/x-mpeg</mime-type>
</mime-mapping>
<mime-mapping>
<extension>ai</extension>
<mime-type>application/postscript</mime-type>
</mime-mapping>
<mime-mapping>
<extension>aif</extension>
<mime-type>audio/x-aiff</mime-type>
</mime-mapping>
<mime-mapping>
<extension>aifc</extension>
</mime-mapping>
<mime-mapping>
<extension>aiff</extension>
</mime-mapping>
<mime-mapping>
<extension>aim</extension>
<mime-type>application/x-aim</mime-type>
</mime-mapping>
<mime-mapping>
<extension>art</extension>
<mime-type>image/x-jg</mime-type>
</mime-mapping>
<mime-mapping>
<extension>asf</extension>
<mime-type>video/x-ms-asf</mime-type>
</mime-mapping>
<mime-mapping>
<extension>asx</extension>
</mime-mapping>
<mime-mapping>
<extension>au</extension>
<mime-type>audio/basic</mime-type>
</mime-mapping>
<mime-mapping>
<extension>avi</extension>
<mime-type>video/x-msvideo</mime-type>
</mime-mapping>
<mime-mapping>
<extension>avx</extension>
<mime-type>video/x-rad-screenplay</mime-type>
</mime-mapping>
<mime-mapping>
<extension>bcpio</extension>
<mime-type>application/x-bcpio</mime-type>
</mime-mapping>
<mime-mapping>
<extension>bin</extension>
<mime-type>application/octet-stream</mime-type>
</mime-mapping>
<mime-mapping>
<extension>bmp</extension>
<mime-type>image/bmp</mime-type>
</mime-mapping>
<mime-mapping>
<extension>body</extension>
<mime-type>text/html</mime-type>
</mime-mapping>
<mime-mapping>
<extension>cdf</extension>
<mime-type>application/x-cdf</mime-type>
</mime-mapping>
<mime-mapping>
<extension>cer</extension>
<mime-type>application/x-x509-ca-cert</mime-type>
</mime-mapping>
<mime-mapping>
<extension>class</extension>
<mime-type>application/java</mime-type>
</mime-mapping>
<mime-mapping>
<extension>cpio</extension>
<mime-type>application/x-cpio</mime-type>
</mime-mapping>
<mime-mapping>
<extension>csh</extension>
<mime-type>application/x-csh</mime-type>
</mime-mapping>
<mime-mapping>
<extension>css</extension>
<mime-type>text/css</mime-type>
</mime-mapping>
<mime-mapping>
<extension>dib</extension>
</mime-mapping>
<mime-mapping>
<extension>doc</extension>
<mime-type>application/msword</mime-type>
</mime-mapping>
<mime-mapping>
<extension>dtd</extension>
<mime-type>application/xml-dtd</mime-type>
</mime-mapping>
<mime-mapping>
<extension>dv</extension>
<mime-type>video/x-dv</mime-type>
</mime-mapping>
<mime-mapping>
<extension>dvi</extension>
<mime-type>application/x-dvi</mime-type>
</mime-mapping>
<mime-mapping>
<extension>eps</extension>
</mime-mapping>
<mime-mapping>
<extension>etx</extension>
<mime-type>text/x-setext</mime-type>
</mime-mapping>
<mime-mapping>
<extension>exe</extension>
</mime-mapping>
<mime-mapping>
<extension>gif</extension>
<mime-type>image/gif</mime-type>
</mime-mapping>
<mime-mapping>
<extension>gtar</extension>
<mime-type>application/x-gtar</mime-type>
</mime-mapping>
<mime-mapping>
<extension>gz</extension>
<mime-type>application/x-gzip</mime-type>
</mime-mapping>
<mime-mapping>
<extension>hdf</extension>
<mime-type>application/x-hdf</mime-type>
</mime-mapping>
<mime-mapping>
<extension>hqx</extension>
<mime-type>application/mac-binhex40</mime-type>
</mime-mapping>
<mime-mapping>
<extension>htc</extension>
<mime-type>text/x-component</mime-type>
</mime-mapping>
<mime-mapping>
<extension>htm</extension>
</mime-mapping>
<mime-mapping>
<extension>html</extension>
</mime-mapping>
<mime-mapping>
</mime-mapping>
<mime-mapping>
<extension>ief</extension>
<mime-type>image/ief</mime-type>
</mime-mapping>
<mime-mapping>
<extension>jad</extension>
<mime-type>text/vnd.sun.j2me.app-descriptor</mime-type>
</mime-mapping>
<mime-mapping>
<extension>jar</extension>
<mime-type>application/java-archive</mime-type>
</mime-mapping>
<mime-mapping>
<extension>java</extension>
<mime-type>text/plain</mime-type>
</mime-mapping>
<mime-mapping>
<extension>jnlp</extension>
<mime-type>application/x-java-jnlp-file</mime-type>
</mime-mapping>
<mime-mapping>
<extension>jpe</extension>
<mime-type>image/jpeg</mime-type>
</mime-mapping>
<mime-mapping>
<extension>jpeg</extension>
</mime-mapping>
<mime-mapping>
<extension>jpg</extension>
</mime-mapping>
<mime-mapping>
<extension>js</extension>
<mime-type>text/javascript</mime-type>
</mime-mapping>
<mime-mapping>
<extension>jsf</extension>
</mime-mapping>
<mime-mapping>
<extension>jspf</extension>
</mime-mapping>
<mime-mapping>
<extension>kar</extension>
<mime-type>audio/x-midi</mime-type>
</mime-mapping>
<mime-mapping>
<extension>latex</extension>
<mime-type>application/x-latex</mime-type>
</mime-mapping>
<mime-mapping>
<extension>m3u</extension>
<mime-type>audio/x-mpegurl</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mac</extension>
<mime-type>image/x-macpaint</mime-type>
</mime-mapping>
<mime-mapping>
<extension>man</extension>
<mime-type>application/x-troff-man</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mathml</extension>
<mime-type>application/mathml+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>me</extension>
<mime-type>application/x-troff-me</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mid</extension>
</mime-mapping>
<mime-mapping>
<extension>midi</extension>
</mime-mapping>
<mime-mapping>
<extension>mif</extension>
<mime-type>application/x-mif</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mov</extension>
<mime-type>video/quicktime</mime-type>
</mime-mapping>
<mime-mapping>
<extension>movie</extension>
<mime-type>video/x-sgi-movie</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mp1</extension>
</mime-mapping>
<mime-mapping>
<extension>mp2</extension>
</mime-mapping>
<mime-mapping>
<extension>mp3</extension>
</mime-mapping>
<mime-mapping>
<extension>mp4</extension>
<mime-type>video/mp4</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mpa</extension>
</mime-mapping>
<mime-mapping>
<extension>mpe</extension>
<mime-type>video/mpeg</mime-type>
</mime-mapping>
<mime-mapping>
<extension>mpeg</extension>
</mime-mapping>
<mime-mapping>
<extension>mpega</extension>
</mime-mapping>
<mime-mapping>
<extension>mpg</extension>
</mime-mapping>
<mime-mapping>
<extension>mpv2</extension>
<mime-type>video/mpeg2</mime-type>
</mime-mapping>
<mime-mapping>
<extension>ms</extension>
<mime-type>application/x-wais-source</mime-type>
</mime-mapping>
<mime-mapping>
<extension>nc</extension>
<mime-type>application/x-netcdf</mime-type>
</mime-mapping>
<mime-mapping>
<extension>oda</extension>
<mime-type>application/oda</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Database -->
<extension>odb</extension>
<mime-type>application/vnd.oasis.opendocument.database</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Chart -->
<extension>odc</extension>
<mime-type>application/vnd.oasis.opendocument.chart</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Formula -->
<extension>odf</extension>
<mime-type>application/vnd.oasis.opendocument.formula</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Drawing -->
<extension>odg</extension>
<mime-type>application/vnd.oasis.opendocument.graphics</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Image -->
<extension>odi</extension>
<mime-type>application/vnd.oasis.opendocument.image</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Master Document -->
<extension>odm</extension>
<mime-type>application/vnd.oasis.opendocument.text-master</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Presentation -->
<extension>odp</extension>
<mime-type>application/vnd.oasis.opendocument.presentation</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Spreadsheet -->
<extension>ods</extension>
<mime-type>application/vnd.oasis.opendocument.spreadsheet</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Text -->
<extension>odt</extension>
<mime-type>application/vnd.oasis.opendocument.text</mime-type>
</mime-mapping>
<mime-mapping>
<extension>ogg</extension>
<mime-type>application/ogg</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Drawing Template -->
<extension>otg </extension>
<mime-type>application/vnd.oasis.opendocument.graphics-template</mime-type>
</mime-mapping>
<mime-mapping>
<!-- HTML Document Template -->
<extension>oth</extension>
<mime-type>application/vnd.oasis.opendocument.text-web</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Presentation Template -->
<extension>otp</extension>
<mime-type>application/vnd.oasis.opendocument.presentation-template</mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Spreadsheet Template -->
<extension>ots</extension>
<mime-type>application/vnd.oasis.opendocument.spreadsheet-template </mime-type>
</mime-mapping>
<mime-mapping>
<!-- OpenDocument Text Template -->
<extension>ott</extension>
<mime-type>application/vnd.oasis.opendocument.text-template</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pbm</extension>
<mime-type>image/x-portable-bitmap</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pct</extension>
<mime-type>image/pict</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pdf</extension>
<mime-type>application/pdf</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pgm</extension>
<mime-type>image/x-portable-graymap</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pic</extension>
</mime-mapping>
<mime-mapping>
<extension>pict</extension>
</mime-mapping>
<mime-mapping>
<extension>pls</extension>
<mime-type>audio/x-scpls</mime-type>
</mime-mapping>
<mime-mapping>
<extension>png</extension>
<mime-type>image/png</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pnm</extension>
<mime-type>image/x-portable-anymap</mime-type>
</mime-mapping>
<mime-mapping>
<extension>pnt</extension>
</mime-mapping>
<mime-mapping>
<extension>ppm</extension>
<mime-type>image/x-portable-pixmap</mime-type>
</mime-mapping>
<mime-mapping>
<extension>ppt</extension>
<mime-type>application/powerpoint</mime-type>
</mime-mapping>
<mime-mapping>
<extension>ps</extension>
</mime-mapping>
<mime-mapping>
<extension>psd</extension>
<mime-type>image/x-photoshop</mime-type>
</mime-mapping>
<mime-mapping>
<extension>qt</extension>
</mime-mapping>
<mime-mapping>
<extension>qti</extension>
<mime-type>image/x-quicktime</mime-type>
</mime-mapping>
<mime-mapping>
<extension>qtif</extension>
</mime-mapping>
<mime-mapping>
<extension>ras</extension>
<mime-type>image/x-cmu-raster</mime-type>
</mime-mapping>
<mime-mapping>
<extension>rdf</extension>
<mime-type>application/rdf+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>rgb</extension>
<mime-type>image/x-rgb</mime-type>
</mime-mapping>
<mime-mapping>
<extension>rm</extension>
<mime-type>application/vnd.rn-realmedia</mime-type>
</mime-mapping>
<mime-mapping>
<extension>roff</extension>
<mime-type>application/x-troff</mime-type>
</mime-mapping>
<mime-mapping>
<extension>rtf</extension>
<mime-type>application/rtf</mime-type>
</mime-mapping>
<mime-mapping>
<extension>rtx</extension>
<mime-type>text/richtext</mime-type>
</mime-mapping>
<mime-mapping>
<extension>sh</extension>
<mime-type>application/x-sh</mime-type>
</mime-mapping>
<mime-mapping>
<extension>shar</extension>
<mime-type>application/x-shar</mime-type>
</mime-mapping>
<mime-mapping>
<extension>shtml</extension>
<mime-type>text/x-server-parsed-html</mime-type>
</mime-mapping>
<mime-mapping>
<extension>smf</extension>
</mime-mapping>
<mime-mapping>
<extension>sit</extension>
<mime-type>application/x-stuffit</mime-type>
</mime-mapping>
<mime-mapping>
<extension>snd</extension>
</mime-mapping>
<mime-mapping>
<extension>src</extension>
</mime-mapping>
<mime-mapping>
<extension>sv4cpio</extension>
<mime-type>application/x-sv4cpio</mime-type>
</mime-mapping>
<mime-mapping>
<extension>sv4crc</extension>
<mime-type>application/x-sv4crc</mime-type>
</mime-mapping>
<mime-mapping>
<extension>swf</extension>
<mime-type>application/x-shockwave-flash</mime-type>
</mime-mapping>
<mime-mapping>
<extension>t</extension>
</mime-mapping>
<mime-mapping>
<extension>tar</extension>
<mime-type>application/x-tar</mime-type>
</mime-mapping>
<mime-mapping>
<extension>tcl</extension>
<mime-type>application/x-tcl</mime-type>
</mime-mapping>
<mime-mapping>
<extension>tex</extension>
<mime-type>application/x-tex</mime-type>
</mime-mapping>
<mime-mapping>
<extension>texi</extension>
<mime-type>application/x-texinfo</mime-type>
</mime-mapping>
<mime-mapping>
<extension>texinfo</extension>
</mime-mapping>
<mime-mapping>
<extension>tif</extension>
<mime-type>image/tiff</mime-type>
</mime-mapping>
<mime-mapping>
<extension>tiff</extension>
</mime-mapping>
<mime-mapping>
<extension>tr</extension>
</mime-mapping>
<mime-mapping>
<extension>tsv</extension>
<mime-type>text/tab-separated-values</mime-type>
</mime-mapping>
<mime-mapping>
<extension>txt</extension>
</mime-mapping>
<mime-mapping>
<extension>ulw</extension>
</mime-mapping>
<mime-mapping>
<extension>ustar</extension>
<mime-type>application/x-ustar</mime-type>
</mime-mapping>
<mime-mapping>
<extension>vxml</extension>
<mime-type>application/voicexml+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xbm</extension>
<mime-type>image/x-xbitmap</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xht</extension>
<mime-type>application/xhtml+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xhtml</extension>
</mime-mapping>
<mime-mapping>
<extension>xml</extension>
<mime-type>application/xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xpm</extension>
<mime-type>image/x-xpixmap</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xsl</extension>
</mime-mapping>
<mime-mapping>
<extension>xslt</extension>
<mime-type>application/xslt+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xul</extension>
<mime-type>application/vnd.mozilla.xul+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xwd</extension>
<mime-type>image/x-xwindowdump</mime-type>
</mime-mapping>
<mime-mapping>
<extension>wav</extension>
<mime-type>audio/x-wav</mime-type>
</mime-mapping>
<mime-mapping>
<extension>svg</extension>
<mime-type>image/svg+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>svgz</extension>
</mime-mapping>
<mime-mapping>
<extension>vsd</extension>
<mime-type>application/x-visio</mime-type>
</mime-mapping>
<mime-mapping>
<!-- Wireless Bitmap -->
<extension>wbmp</extension>
<mime-type>image/vnd.wap.wbmp</mime-type>
</mime-mapping>
<mime-mapping>
<!-- WML Source -->
<extension>wml</extension>
<mime-type>text/vnd.wap.wml</mime-type>
</mime-mapping>
<mime-mapping>
<!-- Compiled WML -->
<extension>wmlc</extension>
<mime-type>application/vnd.wap.wmlc</mime-type>
</mime-mapping>
<mime-mapping>
<!-- WML Script Source -->
<extension>wmls</extension>
<mime-type>text/vnd.wap.wmlscript</mime-type>
</mime-mapping>
<mime-mapping>
<!-- Compiled WML Script -->
<extension>wmlscriptc</extension>
<mime-type>application/vnd.wap.wmlscriptc</mime-type>
</mime-mapping>
<mime-mapping>
<extension>wmv</extension>
<mime-type>video/x-ms-wmv</mime-type>
</mime-mapping>
<mime-mapping>
<extension>wrl</extension>
<mime-type>x-world/x-vrml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>wspolicy</extension>
<mime-type>application/wspolicy+xml</mime-type>
</mime-mapping>
<mime-mapping>
<extension>Z</extension>
<mime-type>application/x-compress</mime-type>
</mime-mapping>
<mime-mapping>
<extension>z</extension>
</mime-mapping>
<mime-mapping>
<extension>zip</extension>
<mime-type>application/zip</mime-type>
</mime-mapping>
<mime-mapping>
<extension>xls</extension>
<mime-type>application/vnd.ms-excel</mime-type>
</mime-mapping>
<mime-mapping>
<mime-type>application/vnd.ms-word</mime-type>
</mime-mapping>
<mime-mapping>
<mime-type>application/vnd.ms-powerpoint</mime-type>
</mime-mapping>
<!-- ==================== Default Welcome File List ===================== -->
<!-- When a request URI refers to a directory, the default servlet looks -->
<!-- for a "welcome file" within that directory and, if present, -->
<!-- to the corresponding resource URI for display. If no welcome file -->
<!-- is present, the default servlet either serves a directory listing, -->
<!-- or returns a 404 status, depending on how it is configured. -->
<!-- If you define welcome files in your own application's web.xml -->
<!-- deployment descriptor, that list *replaces* the list configured -->
<!-- here, so be sure that you include any of the default values that -->
<!-- you wish to include. -->
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
</web-app>
Gummiklokke
Postby stozher » Tue Feb 01, 2011 12:04 pm
I need to view structure and files in "/share/MD0_DATA/.qpkg/Tomcat/tomcat/webapps":
ls -ls /share/MD0_DATA/.qpkg/Tomcat/tomcat/webapps
stozher
Postby Gummiklokke » Tue Feb 01, 2011 12:14 pm
hmmm with telnet?
i tried with my terminal on my mac.. can connect but get this:
-ls: command not found
Gummiklokke
Postby Gummiklokke » Tue Feb 01, 2011 12:17 pm
ROOT/ examples/ manager/ subsonic.war
docs/ host-manager/ subsonic/
Gummiklokke
Postby stozher » Tue Feb 01, 2011 12:22 pm
I need to view structure and files in "/share/MD0_DATA/.qpkg/Tomcat/tomcat/webapps/subsonic"
PP: Duplicate "subsonic.war" and folder "subsonic". Tomcat find in wepapp for war files and extract virtually in memory, or find for folder with extracted war for example...
stozher
Postby Gummiklokke » Tue Feb 01, 2011 12:24 pm
[/share/MD0_DATA/.qpkg/Tomcat/tomcat/webapps/subsonic] # ls -al
drwxr-xr-x 10 tomcat tomcat 4096 Jan 31 12:38 ./
drwxr-xr-x 8 tomcat tomcat 4096 Jan 31 12:38 ../
drwxr-xr-x 3 tomcat tomcat 4096 Jan 31 12:38 META-INF/
drwxr-xr-x 5 tomcat tomcat 4096 Jan 31 12:38 WEB-INF/
drwxr-xr-x 2 tomcat tomcat 4096 Jan 31 12:38 ad/
-rw-r--r-- 1 tomcat tomcat 2122 Jan 22 2010 error.jsp
drwxr-xr-x 2 tomcat tomcat 4096 Jan 31 12:38 flash/
drwxr-xr-x 19 tomcat tomcat 4096 Jan 31 12:38 icons/
-rw-r--r-- 1 tomcat tomcat 115 Oct 8 2009 index.html
-rw-r--r-- 1 tomcat tomcat 115 Oct 8 2009 index.jsp
drwxr-xr-x 5 tomcat tomcat 4096 Jan 31 12:38 script/
drwxr-xr-x 2 tomcat tomcat 4096 Jan 31 12:38 style/
drwxr-xr-x 2 tomcat tomcat 4096 Jan 31 12:38 xsd/
Gummiklokke
Postby stozher » Tue Feb 01, 2011 12:26 pm
OK! Rename "subsonic.war" to "subsonic.war.bak"... and restart server for test.
PP: Use only "subsonic.war" or only extracted version of same file...
stozher
