Problems switching ports
Postby mozztoff » Fri Jan 28, 2011 5:45 pm
running subsonic 4.4 beta 1...
So I had subsonic running fine without any problems on port 80, then I installed VMware on my PC, VMing windows server 08 and now I can't connect through port 80 as I am assuming IIS is using this for its default website. So I changed subsonic to run on port 8080 which works fine, but I get blocked at work because the firewall is blocking 8080. I could access fine from work on port 80. I have since deleted VMware and the VM off my PC, however, I can still not get connection to subsonic when changing back to port 80. Any help??
mozztoff
Postby disgustipated » Fri Jan 28, 2011 6:51 pm
if vmware is completely uninstalled make sure there are no more network devices installed. it installs a bunch of virtual network adapters to share your network connection with the vm.
you might want to check the binding order of your nics also, perhaps subsonic is binding to a different nic's ip than what you are using by forwarding port 80 to your pc
disgustipated
Postby GJ51 » Fri Jan 28, 2011 8:01 pm
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Test your setup by entering your external IP:port# to see if it connects. e.g. http://24.88.76.61:8080/ If it works, you're good to go.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
