Cannot connect the address
Postby wjeppesen » Fri Feb 04, 2011 5:18 am
For some reason I cannot connect to my account online. I get the message "Oops! Google Chrome could not connect to (number)", or something similar on Firefox. I have no idea why. Any thoughts?
wjeppesen
Postby GJ51 » Fri Feb 04, 2011 6:53 am
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding:
ffmpeg -v 0 -ss %o -async 1 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
