Incorrect Stats
Incorrect Stats
Postby john.jays » Fri Feb 04, 2011 3:16 pm
Hi!
I'm using Subsonic 4.4.beta1 and my stats aren't correct.
It shows ~ 3'000 songs less than it should. :roll:
I haven't used any special chars in folder, file and tag names.
There is no error when creating the search index.
Is there a way I could check which files were causing the problem?
I've found something interesting. When I search for "Michelle Branch" it shows me only 2 Albums.. when I click on the Artist, it shows me 3 Albums.
Here are the printscreens:
http://img41.imageshack.us/g/1freesearchoverview.jpg
john.jays
Postby Minime » Fri Feb 04, 2011 3:58 pm
Have you done a new scan since you added new media. Check the settings/Search and trigger a manual rescan. Also check the frequency and set it for daily at a time your SS is likely to be idle.
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
Incorrect Stats
Postby john.jays » Fri Feb 04, 2011 5:09 pm
Yes, i've updated it manually and it's set to update the index every day on 12:00.
john.jays
Newly created index
Postby john.jays » Mon Feb 07, 2011 7:36 am
I've recreated the index with Subsonic 4.4 Final.
Here is what I've got:
http://img155.imageshack.us/i/subsonicsearchindex.jpg/
Created search index with 31628 entries.
and
28,805 songs
john.jays
