Registered, Updated, now ConnectTimeoutException
Postby santucci » Sat Feb 05, 2011 4:44 pm
I just donated, got and installed my license key, and updated to the latest version (4.3), and now Subsonic is no longer working!
Automatic port forwarding and the server worked perfectly during the trial period.
I get a timeout error on the Android app, and when I go to settings>network, it says port forwarding is working, but for the server it says "santucci.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException) ". I thought maybe it was because my domain had expired, so I tried registering another -- that didn't work either.
I searched the forum already, but didn't find any solution. If it is already there, sorry, please post a link.
I am running on Windows 7.
santucci
Postby GJ51 » Sat Feb 05, 2011 5:35 pm
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding:
ffmpeg -v 0 -ss %o -async 1 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
Good choice for frame rate is a "-r 23.976"...
Postby santucci » Sat Feb 05, 2011 10:22 pm
Yep, read that -- that's how I initially set up the server.
I appreciate your taking the time to write out the detailed instructions, but I don't see why you think it is the right solution for my issue. Like I said, everything was working before -- port 80, automatic forwarding.
I didn't change my ISP, or change my router -- all I did was put in my license key and install a new version of the software. So why would there suddenly be an issue with my ISP blocking port 80?
I have messed around with port forwarding before, it's not that I'm afraid to do it. But one of the things I really liked about Subsonic was that I didn't have to. Life is complicated enough, we might as well use the solutions that are out there and let the software do the work for us.
Anyone else have any thoughts on why I'm suddenly getting this error? Should I just install the old version and see if that does the trick?
santucci
Postby santucci » Sat Feb 05, 2011 11:10 pm
Issue resolved, by restarting Windows. :roll:
santucci
Postby alphawave7 » Sun Feb 06, 2011 2:38 am
santucci wrote:Issue resolved, by restarting Windows. :roll:
That will be Gary's next How-To! :p
Postby GJ51 » Sun Feb 06, 2011 4:27 am
Yeah, guess I should include the obvious. :oops:
