mvo wrote:Where is the subsonic.sh file located on a default install on Ubuntu? I used the .WAR file to install.
$ /etc/default/#
# (/etc/init.d/subsonic)
# For example, to specify that Subsonic should use port 7070
# and use a Java memory heap size of 80 MB, use the following:
# SUBSONIC_ARGS="--port=7070 --max-memory=80"# This is the configuration file for the Subsonic service
# For example, to specify that Subsonic should use port 80 (for http)
# and 443 (for https), and use a Java memory heap size of 120 MB, use
# the following:
# SUBSONIC_ARGS="--port=80 --https-port=443 --max-memory=120"
Usage: subsonic.sh [options]
--help This small usage guide.
--home=DIR The directory where Subsonic will create files.
Make sure it is writable. Default: /var/subsonic
--host=HOST The host name or IP address on which to bind Subsonic.
Only relevant if you have multiple network interfaces and want
to make Subsonic available on only one of them. The default value
will bind Subsonic to all available network interfaces. Default: 0.0.0.0
--port=PORT The port on which Subsonic will listen for
incoming HTTP traffic. Default: 4040
--https-port=PORT The port on which Subsonic will listen for
incoming HTTPS traffic. Default: 0 (disabled)
--context-path=PATH The context path, i.e., the last part of the Subsonic
URL. Typically '/' or '/subsonic'. Default '/'
--max-memory=MB The memory limit (max Java heap size) in megabytes.
Default: 100
--pidfile=PIDFILE Write PID to this file. Default not created.
--quiet Don't print anything to standard out. Default false.
--default-music-folder=DIR Configure Subsonic to use this folder for music. This option
only has effect the first time Subsonic is started.
Default '/var/music'
--default-podcast-folder=DIR Configure Subsonic to use this folder for Podcasts. This option
Default '/var/music/Podcast'
--default-playlist-folder=DIR Configure Subsonic to use this folder for playlists. This option
Default '/var/playlists'/etc/default/subsonic/etc/sysconfig/subsonic#
SUBSONIC_ARGS="--port=7070 --https-port=443 --max-memory=80"
SUBSONIC_ARGS="--https-port=443 --max-memory=400"Users browsing this forum: No registered users and 13 guests
