Album artwork problems - SOLVED
Postby onikokoro » Mon Feb 07, 2011 3:57 pm
Currently I’m running subsonic 4.2 on a linux box (Sabayon 5.0) it had been working normally until I rebooted the machine. Now it will only show 1 out of 10 covers or something like that, otherwise it just shows a broken link [Image 1] however if I click on “change” or “zoom” it shows up correctly [Image 2]. I tried with “sudo” and without both with the same result, if I’m missing something novice I apologize but its rather bothersome, and less pretty as well : )
Image 1:
Image 2:
onikokoro
Postby stozher » Tue Feb 08, 2011 12:40 am
Clear browser cache...
stozher
cache
Postby onikokoro » Tue Feb 08, 2011 3:26 am
No effect in IE or Chrome : (
onikokoro
IE and Chrome aren't browsers
Postby john.jays » Tue Feb 08, 2011 7:21 am
IE (M$ sys integrated trojan) and Chrome (love my privacy) aren't browsers.
Try Firefox :wink:
Are your covers embedded as IDv2.3 Tags or are they just inside the directory? Are all covers set the same way?
john.jays
Postby stozher » Tue Feb 08, 2011 2:15 pm
Stop SS and delete thumbs cache folder: ".../subsonic/thumbs"
stozher
SOLVED
Postby onikokoro » Tue Feb 08, 2011 3:06 pm
Fixed it, stopped SS updated all packages to 4.4 started and works like a dream. Still not 100% sure what was causing the problem I'm guessing it was a permissions problem access the cache thumbs. Thanks for everyones help!
onikokoro
