Error when connecting to subsonic
Postby Tekzel » Wed Apr 04, 2007 12:29 pm
Hi. Out of the blue this morning when trying to connect to subsonic from my PC I get the following message. I can connect on the server but I can not log in, it tells me incorrect password on every username I try. I tried stopping the tomcat service and deleting the c:\subsonic\db\subsonic.lck file then restarting the service but got the same result. Any ideas?
Exception org.springframework.jdbc.CannotGetJdbcConnectionException
Message Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@72a11e14[file =C:\subsonic\db\subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: The process cannot access the file because another process has locked a portion of the file : C:\subsonic\db\subsonic.lck
Java version Sun Microsystems Inc. 1.5.0_09
Operating system Windows 2003 5.2
Server Apache Tomcat/5.5.20
Memory Used 13 of 17 MB
Stack trace org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@72a11e14[file =C:\subsonic\db\subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: The process cannot access the file because another process has locked a portion of the file : C:\subsonic\db\subsonic.lck Caused by: java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@72a11e14[file =C:\subsonic\db\subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: The process cannot access the file because another process has locked a portion of the file : C:\subsonic\db\subsonic.lck at org.hsqldb.jdbc.Util.sqlException(Unknown Source) at org.hsqldb.jdbc.jdbcConnection.(Unknown Source) at org.hsqldb.jdbcDriver.getConnection(Unknown Source) at org.hsqldb.jdbcDriver.connect(Unknown Source) at java.sql.DriverManager.getConnection(Unknown Source) at java.sql.DriverManager.getConnection(Unknown Source) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:291) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:277) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:259) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:240) at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:112) at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:516) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:583) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:612) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:620) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:652) at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:45) at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:78) at net.sourceforge.subsonic.service.SecurityService.loadUserByUsername(SecurityService.java:39) at org.acegisecurity.ui.rememberme.TokenBasedRememberMeServices.autoLogin(TokenBasedRememberMeServices.java:151) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:104) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:25) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:36) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:55) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Unknown Source)
Tekzel
Postby sindre_mehus » Wed Apr 04, 2007 12:55 pm
Hm, that's odd... I know it sounds lame, but can you try to reboot?
Postby Tekzel » Wed Apr 04, 2007 1:27 pm
Hey Sindre. Not lame at all, and it was the last thing I tried but forgot to mention it. Did not fix the issue.
I should note that this was after upgrading to version 3.0. Only logged into it once to see how the ads work out, but never saw the ads.
Tekzel
DOH!
Postby Tekzel » Wed Apr 04, 2007 4:54 pm
Ok, i figured it out. I am the sort of person that does not like to delete things until I am sure changes are good. So, I renamed the subsonic.war file in my webapps folder instead of deleting it. When I started the tomcat folder it redeployed it so I was basically running two instances of subsonic. Since old.subsonic is alphabetically before subsonic IT was the one getting the database files. When I tried to connect to subsonic I got the message. I bet if I had tried to use old.subsonic it would have worked fine haha. I just removed the old.subsonic directory and moved the war out to the desktop and restarted the service, problem solved.
Odd though, I am still not seeing those google ads. Not that I particularly WANT to, but would like to help you out if I can.
Tekzel
Users browsing this forum: No registered users and 68 guests
