Question about a web player
Postby Jabberwock » Wed Feb 09, 2011 10:25 am
Does the webplayer use Flash 10? If so, is it possible to use a lower version player?
I am trying to stream music to my Archos 5 IMT (non-Android) and control it via Web from another computer. Subsonic seemed like a solution, unfortunately, even though I see the Subsonic page on the device and can add songs to a playlist, sound is not produced at all.
Could it be due to the fact that Archos has not upgraded to Flash 10? Is there any workaround for this?
Jabberwock
Postby stozher » Wed Feb 09, 2011 9:57 pm
Adobe Flash 9.0.115 and above for JW Player 5.4 video :idea:
stozher
Postby Jabberwock » Wed Feb 09, 2011 10:05 pm
Is JW Player what is used in Subsonic page? With Flash 9 Archos should work... I am not sure why it doesn't :(
Jabberwock
Postby Jabberwock » Thu Feb 10, 2011 1:33 am
Unfortunately, it seems Archos 5 is running a limited-feature version - Flash 9 Lite. I've read it is incompatible with JW Player...
Oh, too bad - I had high hopes for this setup...
Jabberwock
Postby Jabberwock » Thu Feb 10, 2011 11:05 pm
Maybe another avenue has opened: Archos 5 can be hacked to install Angstrom. This distribution is also quite limited - Flash does not work either in the browser, but at least there is more room for experiments...
Jabberwock
