Error 503 Service Unavailable
Postby mberma2 » Thu Feb 10, 2011 2:54 am
I had a 2 month run with not a single problem......now I have had a month of nothing BUT problems with Subsonic. I am running a Dell desktop with Windows XP. I have tried every version of Subsonic imaginable. The error messages change but the service remains down. Any thoughts?
mberma2
Postby GJ51 » Thu Feb 10, 2011 3:39 am
If your having problems. Reboot the server. If that doesn't work, uninstall/reinstall Java. If still no joy, try reinstalling SS right over the top of the current SS using the latest version. If that all fails move on to the following:
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X Always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding:
ffmpeg -v 0 -ss %o -async 1 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
Good choice for frame rate is a "-r 23.976"...
ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 30 -s %wx%h -ar 44100 -ac 2 -
Stozher's mp4 > flv transcoding : ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
Postby mberma2 » Thu Feb 10, 2011 5:34 am
I am not using a router. It is a pc hard wired to a cable modem....high speed.
mberma2
Postby mberma2 » Thu Feb 10, 2011 5:41 am
Comcast internet....newest version of Java......and a huge RED Subsonic logo after working for months
mberma2
Postby GJ51 » Thu Feb 10, 2011 6:25 am
mberma2 wrote:I am not using a router. It is a pc hard wired to a cable modem....high speed.
Now he tells me ...
I should have gone into dentistry.
Postby GJ51 » Thu Feb 10, 2011 6:26 am
Have you rebooted the PC?
Postby mberma2 » Thu Feb 10, 2011 2:29 pm
Over the past week, I have rebooted, uninstalled, and redownloaded everything and still.....nothing
mberma2
Postby GJ51 » Thu Feb 10, 2011 4:16 pm
What port? Which version of SS?
