4.4 Windows 7 Can't start subsonic
Postby hollowpoint » Fri Feb 11, 2011 12:42 am
Anyways,
Upgraded to 4.4 on windows 7 64 bit. Problem is once I stop the service I cannot start it again. When I go into the services area of windows and try to start subsonic I get "Windows could not start the subsonic service on local computer: Error 1 Incorrect Function" It does work if I reinstall subsonic, but only until I try to restart the service.
Anyone got any ideas?
Thanks again
hollowpoint
Postby GJ51 » Fri Feb 11, 2011 4:56 am
Have you tried a reboot?
Postby hollowpoint » Fri Feb 11, 2011 8:50 am
Indeed I have. It seems only to work after I reinstall and once I restart, it no longer works. It's windows 7 64 and I have had all the way up to 4.2 working but this latest build does not seem to play nice with my setup right now.
hollowpoint
Postby GJ51 » Fri Feb 11, 2011 8:52 am
Any clues in the event logs? I would also consider a Jave uninstall/reinstall.
Are you attempting to restart from the SS Control Panel or the Windows Services.msc?
Postby hollowpoint » Fri Feb 11, 2011 10:16 pm
Yep, still no dice.
Reinstalled java and subsonic. Nothing changed, still getting the incorrect function error when trying to start through windows services and when I click start in the tray it just sits there and does nothing.
hollowpoint
Postby GJ51 » Fri Feb 11, 2011 10:25 pm
Must be a Windows issue.
Postby hollowpoint » Fri Feb 11, 2011 10:29 pm
Funny you mention that actually, just needed to wipe out the subsonic folder and now it works just fine. Quite odd, really.
hollowpoint
Postby GJ51 » Fri Feb 11, 2011 10:53 pm
Yup! I've consistently found that if the underlying OS is OK, a clean uninstall/reinstall of both Java and SS works just dandy. Most times, just a reinstall of SS right over the previous install cures most issues, but sometimes you really do need a CLEAN install. i.e. remove the old SS directory completely.
Glad to see you're back up!
Cheers!
