Why don't my transcoders work - Ubuntu 10.04
Postby user68 » Fri Feb 11, 2011 4:46 pm
I don't know why but i no longer have any transcoders in /var/subsonic/transcoder. I followed the instructions to install them again, sudo apt-get install lame flac fadd.....etc but it tells me I already have the newest versions. I did a search and I can see them in different directories like usr/share and usr/bin.
How do I get Subsonic to use these transcoders?
user68
Postby Poffa » Fri Feb 11, 2011 4:53 pm
cp /usr/bin/lame(and others) /var/subsonic/transcode
Symlinks don't work for me.
Poffa
Postby user68 » Fri Feb 11, 2011 5:16 pm
Thanks Poffa, that's fixed it. I moved lame, flac, faad and ffmpeg to /var/subsonic/transcode. Not sure if I'm getting Flac converted to MP3 though. In the log I get "(/var/subsonic/transcode/ffmpeg) WARNING: library configuration mismatch"
Does this suggest I'm getting MP3 output?
[2011-02-11 17:06:27,388] INFO PlaylistInputStream - mark listening to "Nirvana - In Utero [MFSL]/Nirvana - In Utero (MFSL) - 01 - Serve The Servants.flac"
[2011-02-11 17:06:27,395] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/home/mark/Music/Nirvana - In Utero [MFSL]/Nirvana - In Utero (MFSL) - 01 - Serve The Servants.flac] [-v] [0] [-f] [wav] [-]
[2011-02-11 17:06:27,457] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [2147483647] [--tt] [Serve The Servants] [--ta] [Nirvana] [--tl] [In Utero (MFSL)] [-S] [--resample] [44.1] [-] [-]
[2011-02-11 17:06:27,655] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.6.1-4:0.6.1-2ubuntu1~ppa1~lucid2, Copyright (c) 2000-2010 the FFmpeg developers
[2011-02-11 17:06:27,656] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) built on Nov 21 2010 02:02:54 with gcc 4.4.3
[2011-02-11 17:06:27,656] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) configuration: --extra-version='4:0.6.1-2ubuntu1~ppa1~lucid2' --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
[2011-02-11 17:06:27,656] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) WARNING: library configuration mismatch
[2011-02-11 17:06:27,657] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil configuration: --extra-version='4:0.6.1-2ubuntu1~ppa1~lucid2' --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libmp3lame --enable-libdc1394 --enable-shared --disable-static
[2011-02-11 17:06:27,657] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec configuration: --extra-version='4:0.6.1-2ubuntu1~ppa1~lucid2' --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libmp3lame --enable-libdc1394 --enable-shared --disable-static
[2011-02-11 17:06:27,658] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil 50.15. 1 / 50.15. 1
[2011-02-11 17:06:27,658] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec 52.72. 2 / 52.72. 2
[2011-02-11 17:06:27,658] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavformat 52.64. 2 / 52.64. 2
[2011-02-11 17:06:27,658] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[2011-02-11 17:06:27,658] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavfilter 1.19. 0 / 1.19. 0
[2011-02-11 17:06:27,659] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[2011-02-11 17:06:27,659] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2011-02-11 17:06:27,805] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmp
user68
Postby stozher » Sat Feb 12, 2011 2:33 am
Reinstall FFmpeg...
stozher
