Changing the "working" directory for Subsonic
Postby bushman4 » Fri Feb 11, 2011 8:30 pm
As part of an effort to enable multiple Subsonic instances on one machine, I have found that the biggest obstacle is the "working" directory of /var/subsonic or c:\subsonic depending on the platform.
Does anyone know where in the WAR file this is specified? I've been hunting around for a half hour or so but can't seem to come up with where it is set.
If it is an easy change then my problem is solved...
Thanks in advance,
Glenn
