[SOLVED] ClientProtocolException ??
Postby JanoLapin » Sat Feb 12, 2011 9:55 pm
I use Subsonic (registered) on an Ubuntu Server 10.10 with Tomcat 6 + SSL
When I try to register a redirection (xxxxx.subsonic.org) I have this message :
Status: xxxxxx.subsonic.org is registered, but could not connect to it. (ClientProtocolException)
I don't understand ...
And you ?
JanoLapin
Postby alphawave7 » Sat Feb 12, 2011 10:38 pm
check canyouseeme.org for your chosen SS port that's forwarded...is it working?
Postby JanoLapin » Sat Feb 12, 2011 11:30 pm
alphawave7 wrote:check canyouseeme.org for your chosen SS port that's forwarded...is it working?
Yes
Success: I can see your service on xx.xx.xx.xx on port (xxxx)
Your ISP is not blocking port xxxx
I use SSL, is it the problem ?
EDIT and when I use my reverse DNS Subsonic works
JanoLapin
Postby alphawave7 » Sat Feb 12, 2011 11:59 pm
SS should update it's address (overnight, IIRC), so it may just be a delay..how long has it been doing this? WRT SSL, I don't use it, so don't know what ramifications (logins?) that poses.
Postby JanoLapin » Sun Feb 13, 2011 12:01 am
I'll wait but I'm not shure that fix it ...
Thanks for answer.
JanoLapin
Postby alphawave7 » Sun Feb 13, 2011 12:40 am
JanoLapin wrote:I'll wait but I'm not shure that fix it ...
Thanks for answer.
I discovered your port is not passing a security check on Chrome, so it may be that it's also failing on Sindre's server. Bypassing this error page get me to your login, so at least that's working. :)
Postby JanoLapin » Sun Feb 13, 2011 1:03 am
alphawave7 wrote:I discovered your port is not passing a security check on Chrome, so it may be that it's also failing on Sindre's server. Bypassing this error page get me to your login, so at least that's working. :)
you talk about self signed certificate error ?
JanoLapin
Postby JanoLapin » Sun Feb 13, 2011 5:53 pm
SOLVED !
Must register the xxxxx.subsonic.org without SSL (HTTP).
And only after enable "force SSL" in Tomcat.
And it's works :)
But i think i can't use this address (xxx.subsonic.org) in Android app, i mist type the "long" url (with SSL port), i'll test that.
A more efficient SSL support in Subsonic will be great...
JanoLapin
