Setting port#
Re: Setting port#
Postby WPWoodJr » Sun Feb 13, 2011 4:19 pm
al wrote:My Verizon blocks port 80. I have not found where to change port#. The instructions call for clicking on the Subsonic tray icon, but this does nothing. There is also no setting for this under settings>network. I'm running Subsonic 4.4 on Windows XP.
Try right-clicking on the Subsonic icon in the system tray. I used port 14545.
WPWoodJr
Postby GJ51 » Sun Feb 13, 2011 5:01 pm
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
You will have to manually set port forwarding in the router as the Verizon routers are NOT Plug & Pray.
Postby GJ51 » Sun Feb 13, 2011 7:05 pm
If nothing is happening when you right click on the tray icon, then the SS service is not installed properly. Delete the Subsonic directory and redo the install. If you have any suspicion that Java is not up to date, uninstall it and reinstall the latest Java before reinstalling SS. A good ol reboot before the reinstalls isn't a bad idea either.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Postby WPWoodJr » Sun Feb 13, 2011 7:31 pm
One other thing - some of the documentation says to port forward TCP and UDP but I asked Sindre and only TCP is used by Subsonic.
WPWoodJr
Postby dcuellar » Mon Feb 14, 2011 2:34 am
If subsonic is automatically set to 4040, how do I set it manually to a different port. I'm using a mac.
dcuellar
