cannot open my SS website. xxxxxx.subsonic.org ?
Postby davidgibs0n » Sun Feb 13, 2011 5:13 pm
when retrying the autosetup port forward in the SS interface it says port 80 successfully forwarded and then
xxx.subsonic.org is registered, but could not connect to it.
any ideas? shouldnt be a router issue.. i havent changed a thing and it has worked for a year or so now..
davidgibs0n
Postby GJ51 » Sun Feb 13, 2011 6:14 pm
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
