Not able to change settings
Postby wjeppesen » Sun Feb 13, 2011 10:31 pm
I am not able to change the settings in subsonic tray. I want to change the port, but when I try to save it, I get this message.
"Failed to write to file C:\Program Files (x86)\subsonic-service.exe.vmoptions subsonic-service.exe.vmoptions (Access is denied)"
Any thoughts? Also, I cannot get the service to stop by clicking "Stop." Thanks for your help.
wjeppesen
Postby GJ51 » Sun Feb 13, 2011 10:41 pm
I ran into the same thing a while back. Had to do a reinstall to fix it.
Postby bornonline » Mon Feb 14, 2011 2:20 am
I had the same problem today. The problem is I'm not sure what fixed it.
I changed the service to run under a local admin account. I also changed the exe to run as administrator in Windows 7. I also checked permissions on those files too.
I was getting the exact error as you and could not control the service from the tray icon. It is working now and I did not reinstall.
bornonline
Still doesn't work
Postby wjeppesen » Tue Feb 15, 2011 4:41 am
I tried uninstalling it and installing again, but I still can't change the settings!
wjeppesen
