Permissions issues on OSX 10.5, Subsonic 4.4
Postby shaddi » Mon Feb 14, 2011 6:52 am
I just installed Subsonic 4.4 with no issues on OSX 10.5.8. When I start Subsonic, I get the following error message in the Subsonic control panel:
java.lang.IllegalArgumentException: Bad temp directory: /Library/Application Support/Subsconic/jetty/2169
When I initially installed Subsonic, this directory was not there. I tried manually creating the directory, but I still got this error. The error went away after I chmod 777'd the directory, but despite no longer seeing it the web interface returns a 503 when I load it ,so it seems that something funky is going on with my permissions.
Do I need to run Subsonic as root from now on, or is there some way to get it running under a non-root account that I missed during install? Thanks!
shaddi
Postby Mamer » Wed May 25, 2011 6:59 am
Just installed it on my Mac Mini running 10.5.8 and I'm having the exact same issue. I changed the permission and the error is gone but I'm getting that 503 error mentioned above. Anyone know what this is all about?
The exact error is this...
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
Mamer
Re: Permissions issues on OSX 10.5, Subsonic 4.4
Postby AlphaRampage » Thu Feb 21, 2013 9:01 pm
I also had this same problem on my Macbook running OSX 10.5.8 with the most recent version of Subsonic.
I see this still isn't resolved. Could somebody try to figure it out?
AlphaRampage
