Can't create playlists
Postby JonasKeinholz » Mon Feb 14, 2011 1:54 pm
I'm using Subsonic 4.4 (build 2169) – 6. Februar 2011 on Ubuntu 10.04.1 Server 32-Bit (jetty-6.1.x, java 1.6.0_22, Linux (26,9 MB / 60,2 MB)).
I can't create playlists. When I chose "More Actions" -> "Playlist" -> "Save" there comes the following error message:
Exception   java.lang.ClassFormatError
Message   Truncated class file
Java version   Sun Microsystems Inc. 1.6.0_22
Operating system   Linux 2.6.32-24-generic-pae
Server   jetty-6.1.x
Memory   Used 30 of 52 MB
Stack trace   java.lang.ClassFormatError: Truncated class file
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
   at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
   at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
   at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:133)
   at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:65)
   at org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:596)
   at org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:147)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:315)
   at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
   at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
   at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
   at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
   at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
   at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
I have no idea what's wrong. The playlist folder is located under /var/playlists and is owned by root:root (chmod 755).
Anyone an idea what's going wrong? Thanks in advance for your help
Greetings,
Jonas
JonasKeinholz
Postby grnidb » Thu Feb 17, 2011 3:03 pm
Are you able to load any of your playlists? Has the playlist ever worked? I would be interested to see if you can access your playlist via another folder.
grnidb
