Can Subsonic be installed on a Dlink DNS-323 NAS?
Postby demonstreamer » Tue Feb 15, 2011 7:39 pm
Can Subsonic be installed on a Dlink DNS-323 NAS? I cant tell from the specs if other software can be installed. I currently have Subsonic serving from my main PC, figure it would be safer to run it on a dedicated machine.
If the above NAS wont work, anyone recommend a low costs NAS that can be used as a dedicated media hub with Subsonic installed?
demonstreamer
Postby GJ51 » Tue Feb 15, 2011 8:32 pm
http://www.newegg.com/Product/Product.a ... -_-Product
Then add any 2.5 hard drive you like.
Postby bluetooth » Mon Feb 21, 2011 5:57 pm
I own a DNS-323. In my experience, the UI is just too slow to be useful when using the DNS. I wish it was otherwise, but for me it was unusable. I have worked with other NAS boxes, like the QNAP TS219P and that particular box can push data 5X faster than the DNS.
paid Subsonic user
bluetooth
Install on new Dlink DNS 320 or 325
Postby nopub » Sat Feb 26, 2011 12:11 pm
bluetooth wrote:I own a DNS-323. In my experience, the UI is just too slow to be useful when using the DNS. I wish it was otherwise, but for me it was unusable. I have worked with other NAS boxes, like the QNAP TS219P and that particular box can push data 5X faster than the DNS.
I installed the new NAS Dlink DNS 320.
These performances are more important than the old model DNS323
Also I want to install Subsonic in this model. Do you think this is possible. How, I'm new in Linux NAS. Apparently you succeded to install JAVA on the model DNS 323. Can you explain the method in ssh with Putty example. I already install fun_plug & Optware, it can help?
Thank you in advance.
__________
Bonjour,
J'ai installé le nouveau NAS Dlink DNS 320.
Ces performances sont plus importantes que l'ancien modèle DNS323
Aussi je souhaiterai installer Subsonic sur ce modèle. Pensez vous que cela est possible. Comment procéder, je suis débutant en NAS Linux. Apparement tu as reussi à installer JAVA sur le modèle DNS 323. Pouvez vous m'expliquer la méthode en ssh avec Putty par exemple. J'ai deja installer fun_plug et optware, ca peut aider?
Merci d'avance.
nopub
Postby bluetooth » Sat Feb 26, 2011 2:01 pm
I never had subsonic running on the DNS-323, I only used it to store music.
paid Subsonic user
bluetooth
Postby 3R3 » Sat Mar 05, 2011 7:34 pm
3R3
