Subsonic on clearos
Subsonic on clearos
Postby Fastbob » Thu Feb 17, 2011 10:12 pm
Hi guys,
Im trying for the second evening in a row to get subsonic running on my clearos 5.2.
I have managed to install java and as far as I can see also Subsonic.
Although I used the standalone version for installation.
Unfortunately I am not able to get the logon screen and the log file of subsonic mentions something strange about the database:
Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@2d6451a6[file =/var/subsonic/db/subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: checkHeartbeat(): lock file [/var/subsonic/db/subsonic.lck] is presumably locked by another process.
When I trie to log in to my subsonic server x.x.x.x:4040 I get the following mesasage:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/subsonic
Powered by jetty://
As I have managed to get al sort of progs running on my clearos server I am a bit further than a noob but at the moment I am out of ideas.
Who can help me out?
Fastbob
Fastbob
Postby oeh » Thu Feb 17, 2011 11:39 pm
What version of SS are you using?
Seems some other process are using these resources. Have you checked the status of SS.
Regards
OEH ;-}
oeh
Postby Fastbob » Fri Feb 18, 2011 6:36 pm
Hi oeh,
The latest version 4.4 downloaded and installed.
Fastbob
Postby Fastbob » Fri Feb 18, 2011 7:08 pm
Ho oeh,
Made a reinstall with rdp file and now it works.
Thanks anyway.
Fastbob
Fastbob
Postby oeh » Sat Feb 19, 2011 11:28 pm
:D God to hear that you got it to work.
Regards
OEH ;-}
oeh
Postby Fastbob » Sun Feb 20, 2011 10:10 am
Well, as it turns out it works for the biggest part.
But I made another topic on the network connection from ClearOS to my NAS. I can not get through to my NAS and I do not know how this can be achieved.
Regards,
Fastbob
Fastbob
Re: Subsonic on clearos
Postby CasN » Mon Jan 28, 2013 7:51 pm
I have got the same message on Clearos 6.3. I had it working, added my mp3's, all ok.
Today I received the same message. I uninstalled the rpm and installed it again. Same result.
Changed the ports, still same result.
Any suggestsions :(
CasN
Postby CasN » Tue Jan 29, 2013 7:24 pm
Still do not know the reason but fixed by it reinstalling java & subsonic (i did had to remove all subsonic files ) :mrgreen:
CasN
