Problem creating podcast directory
Postby Mikedaub » Fri Feb 18, 2011 4:05 pm
Every podcast I try to add into the podcast receiver to start downloading always gives me the same error:
java.lang.RuntimeException: Failed to create directory /var/music/Podcast/Pacha NYC Podcast
You can replace the Pancha NYC Podcast with whatever other podcast I try adding. I am using valid links, copied from my podcast receiver on my phone, but always gives me the same error.. Do I need to create the folder on my server first? I do have the main folder of Podcast already created, but not folders for the individual folders for each podcast
Any thoughts?
Mikedaub
Postby baaldemon » Fri Feb 18, 2011 4:35 pm
What operating system are you running? Are you sure that /var/music/Podcast/ has the correct permissions for the user you are running subsonic with?
baaldemon
Postby djsubsonic » Fri Feb 18, 2011 7:07 pm
Or Maby Create the directorie...
I'm A Dutch Guy And I'm Sorry If My English Is Crep:$ But I Think That You Guys Understand Me.
djsubsonic
Postby Mikedaub » Fri Feb 18, 2011 7:07 pm
Thanks for the reply.
I got it fixed. I am not sure what the problem was, but it is fixed. I sent this link to my IT guy and he did whatever needed to be done.
Another question about podcasts, how can they be deleted? Do they auto delete once they are listened to, do I have to go into the directory and do it? It doesn't seem like there is a setting for it anywhere..
thanks
Mikedaub
Postby Minime » Fri Feb 18, 2011 11:40 pm
Once you configure your podcasts settings(Number of episodes to keep, how frequent SS will check for new episodes etc) from: Settings > Podcasts, it's all managed by subsonic automatically.
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
Podcast title must be a valid directory name
Postby zvi31 » Sat Feb 19, 2011 9:55 am
I received a similar error when subscribing to <http://feeds.pbs.org/pbs/wgbh/nova-video>.
java.lang.RuntimeException: Failed to create directory c:\music\Podcast\NOVA Vodcast | PBS
Subsonic could not create the podcast directory because the podcast title, used for the directory name, contains "|" which cannot be used in naming a Windows directory.
I ended up modifying removeMarkup() in StringUtil.java, which is used to clean podcast title and episode name, so that it replaces "|" with "-".
Cheers,
--Zvi
zvi31
Postby mbohde » Tue Feb 22, 2011 4:58 pm
I am having the exact same problem with the | in the name. I just downloaded a tool called ClassEditor to modify this however am new to java. Could you give me the line number or a string to search for and how it needs to be modified? Thanks.
mbohde
Postby zvi31 » Fri Feb 25, 2011 10:41 pm
The class to modify is net.sourceforge.subsonic.util.StringUtil
Original
    public static String removeMarkup(String s) {
        if (s == null) {
            return null;
        return s.replaceAll("<.*?>", "");
Modified
        if (s == null) {
            return null;
        s = s.replaceAll("[|]", "-");  // Replace "|" with "-"
        return s.replaceAll("<.*?>", "");  // Remove HTML tags
If you can patch the class file, try to substitute this "<.*?>" with this "(<.*?>)|[|]". The effect would be to remove the "|" from the filtered string.
Good luck,
--Zvi
zvi31
