Can connect to port 80 but cannot connect name
Postby magnumforce2006 » Sat Feb 19, 2011 9:21 am
Hi there, I'm able to connect to port 80 successfully, but under accessing server using name... I get
"Status: mf2k6.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException) "
Any ideas? My log only shows that I'm successfully forwarding port 80.
magnumforce2006
Postby oeh » Sat Feb 19, 2011 11:27 pm
Have you forwarded this port on your router?
Does not look as you have. I can reach your ip.
Regards
OEH ;-}
oeh
Postby magnumforce2006 » Sun Feb 20, 2011 10:20 pm
It appears as if I am... check out the screen shot:
magnumforce2006
Postby GJ51 » Sun Feb 20, 2011 11:07 pm
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Postby magnumforce2006 » Mon Feb 21, 2011 6:40 am
Hm, I actually changed my admin account to a new one, and it works.
magnumforce2006
Postby GJ51 » Wed Feb 23, 2011 2:29 am
Go figure ... 8)
