Subsonic Can't Connect From Outside Home Network
Postby Funk#49 » Sun Feb 20, 2011 3:00 pm
OK, so I've been trying for a couple days to get Subsonic up and running and finally ditch my iPod for good, but I'm having some problems.
I followed these setup instructions: http://monroeworld.com/android/subsonic/
I have a static IP set on my PC that is running the subsonic server.
When I run IP CONFIG it lists my IP as 192.168.1.125 (what I set it to in the router interface), but when I go to canyouseeme.org to test the port, it thinks my IP is 67.87.2.230.
I can connect from within my home network, but can't reach my domain from anywhere outside the network.
My server is http://nicksmusic.subsonic.org.
Any help would be much appreciated. I tried a lot of the troubleshooting in this forum but can't seem to get it to work.
Funk#49
Postby alphawave7 » Mon Feb 21, 2011 5:33 pm
Canyouseeme is working just fine..it will always report your public IP, and never your private. ;) You have to follow the directions in you router's manual to successfully open a port for Subsonic, verified by testing with canyouseeme.org until it can see the port open. Only then will outside access work. What router maker, revision and model do you have?
Postby donpearson » Mon Feb 21, 2011 9:47 pm
Looks like you got it going now.
Facebook Group:
donpearson
Postby Funk#49 » Tue Feb 22, 2011 1:28 am
I switched ports and it worked fine. Thanks for the quick replies!
Funk#49
Postby tigerstyle » Wed Feb 23, 2011 6:21 am
Congrats Funk#49. I purchased Subsonic 5 months ago and I have been trying to make subsonic run remotely but I have had no success. I have read Monroe's guide thoroughly but it doesn't work for me. I have tried different ports and canyouseeme.org shows them as closed. I have a D-Link Dir-825 router rev a. Can someone help me?
tigerstyle
Postby alphawave7 » Wed Feb 23, 2011 7:14 am
tigerstyle wrote:Congrats Funk#49. I purchased Subsonic 5 months ago and I have been trying to make subsonic run remotely but I have had no success. I have read Monroe's guide thoroughly but it doesn't work for me. I have tried different ports and canyouseeme.org shows them as closed. I have a D-Link Dir-825 router rev a. Can someone help me?
On your router, this page:
http://support.dlink.com/emulators/dir8 ... erver.html
Manual Here:
ftp://ftp.dlink.com/Gateway/dir825/Manu ... al_110.zip
Application name: Subsonic
IP Address: IP of Subsonic machine
on TCP/UDP: select Both
on Port: 8080 for both public and private
Select 'Save Settings' above when done, then reboot router. Once router comes up, go to canyouseeme.org and test port 8080.
Postby GJ51 » Thu Feb 24, 2011 2:15 am
Try rebooting the router.
Postby tigerstyle » Thu Feb 24, 2011 5:00 am
I tried alphawave7's suggestion and also tried rebooting my router but I am unable to get port forwarding to work. About 2 months back I purchased pfconfig to forward ports but had no luck. I even tried my old router which is a Linksys WRT54GS with dd-wrt and that didn't work. My ISP is Comcast, have you heard if they block certain ports? Thanks.
tigerstyle
Postby alphawave7 » Thu Feb 24, 2011 6:04 am
tigerstyle wrote:I tried alphawave7's suggestion and also tried rebooting my router but I am unable to get port forwarding to work. About 2 months back I purchased pfconfig to forward ports but had no luck. I even tried my old router which is a Linksys WRT54GS with dd-wrt and that didn't work. My ISP is Comcast, have you heard if they block certain ports? Thanks.
If your router has a firmware upgrade available, I suggest doing that...it seems your existing firmware is not working as designed, and may require a full factory reset and/or reflash of latest firmware to regain the default functionality. :|
edit: I'm unaware of Comcast blocking any ports, but 80 would be one of the first ports they would block for servers. I'd recommend something easy to remember, like 4040, 5050,etc.
Postby GJ51 » Thu Feb 24, 2011 12:22 pm
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Postby tigerstyle » Fri Feb 25, 2011 4:24 am
GJ51, I tried your method but didn't get it working, alphawave7 my router has the latest firmware so that's not the problem. Also I just realized today that I have Vonage router vdv21-vd, I didn't even know it was router until I Googled it. I logged into the Vonage router and tried forwarding different ports but it didn't work. Then I completed removed the Vonage router and tried port forwarding and checked on canyouseeme.org and it gave me a timeout error. So after about 5 months of trying I am calling it quits. Would have loved to have my whole music collection in my pocket-oh well. Thanks for your help alphawave7 and GJ51.
tigerstyle
Postby alphawave7 » Fri Feb 25, 2011 4:28 am
Sorry it's so frustrating..but there IS a solution that simply awaits discovery. Knowing there's another router (and possibly an SPI firewall there too) does make the first efforts pointless. /sigh
Always willing to help if you want to revisit it. :D
Postby GJ51 » Sat Feb 26, 2011 1:42 am
As is often the case, the devil is in the details. Your Vonage router does NOT need to be in front of the router in the network. Vonage has several different units they've used over the years, but you should find out what you need to do to disable DHCP on the Vonage unit anyway as it will wreak havoc with your network if both units are trying to control DHCP. Disable DHCP in the Vonage unit and just plug it into the router or any switch on your network. I switched from Vonage to OOMA recently and the same strategy applied. All the VOIP vendors try to get you to install their unit in front of your router so that they get better bandwidth/quality. This may be an issue if you have almost no bandwidth, but on today's connection it's almost never an issue anymore. I switched from Vonage to OOMA, and now instead of $25/mo. I only pay $3.47/mo which is just taxes and fees from the govt.
If it's any consolation, all routers are different and all of them are pretty arcane when it comes to port forwarding. No doubt you just haven't hit the right combination for entering the forwarding properly. Perhaps the D-Link support people could walk you through it. Sorry it's been such a struggle for you. As always, I second Alphawave7, we'll be glad to help if decide to give it another try sometime. We both worked with another user that had the same difficulty that your having, but after several weeks, he finally got it to work. I think it was one of the highlight of his life! Let us know when you're ready to give it another go.
Postby donpearson » Sat Feb 26, 2011 1:54 am
Just a quick note, you can also get your external IP address from the image in my Signature, it's in the bottom left hand corner next to Subsonic HELP?
Only YOU can see your ip address in the image, no one else can get the info.
Facebook Group:
donpearson
Postby jakobedlam » Sat Apr 09, 2011 2:49 am
GJ51 wrote:As is often the case, the devil is in the details. I switched from Vonage to OOMA, and now instead of $25/mo. I only pay $3.47/mo which is just taxes and fees from the govt.
GJ51, I recently switched from a land line to Ooma myself. Great phone service, but I can't get to subsonic from outside my house. In the network, no problem. But not from the outside. I followed Ooma's advice and put the device in front of the router. Honestly, the call quality is better, and none of the few hiccups we had when it was behind the router. But Subsonic stopped working (was working fine when Ooma was behind the router).
Any suggestions? My router is D-LINK IR 665
jakobedlam
