Buffering Issues with 4.4
Postby bluetooth » Tue Feb 22, 2011 8:43 pm
I've tried this with the web player, winamp and Media Monkey players. I can't seem to get a music stream playing reliably. Both the subsonic server and the client are on GB Ethernet, utilization less than 1% when playing.
I have now downgraded to 4.2, and now it seems to be working.
Any one else having buffering issues? Any suggestions how to possibly troubleshoot something like this?
Cliff
paid Subsonic user
bluetooth
Postby jeffcavicchi » Tue Feb 22, 2011 9:23 pm
After I upgraded to 4.3/4.4 I started to get a slight hesitation right at the beginning of playback (between 0-1 seconds). Rest of the song plays fine. Seems like a buffering problem to me.
I have been communicating a bit with Sindre about this - seems like a problem with the new JW Player maybe?
How is your problem manifesting itself, exactly?
jeffcavicchi
Postby bluetooth » Tue Feb 22, 2011 9:30 pm
I typically use Winamp instead of the internal player. I like to have the lyrics popup and I can't get those in the internal player - otherwise it's fine.
Quick Summary:
I5 running Win7 x64 with 8GB RAM
GB Ethernet
Some adapter settings:
Jumbo Frames ON
Large Send Offload Enabled
TCP Checksum Enabled
When I first upgraded to 4.4 I was getting erratic buffering problems with Winamp. Moving to the internal player seemed a bit better, but still had issues.
Then finally today it was unplayable no matter what I tried. I increased Memory to Subsonic to 192MB without any impact.
So, I turned of jumbo frames, disabled the other adapter settings above. Still no happiness. I downgraded to 4.2 and it is working perfectly again.
paid Subsonic user
bluetooth
