Having trouble with windows/android setup
Postby goathouse774 » Wed Feb 23, 2011 2:56 am
I've got the server installed and the app installed. my main problem is that when I test the server I designated while in the app there is a network error. I looked at the tutorial for this configuration and I feel like I've done all that. Any help would be appreciated.
goathouse774
Postby GJ51 » Wed Feb 23, 2011 3:36 am
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
