Trouble with Transcoding
Postby toekneebullard » Fri Feb 25, 2011 7:43 pm
I'm having issues with my video setup.
OSX 10.6.6
I went through the Transcoding troubleshooting list, and everything checks out OK. When I try and play a video I get a "Video not found or access denied:" error, with a whole lot of long variables after it. Can't copy and paste it out of the player window.
Here's my log:
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) minor_version : 537199360
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) compatible_brands: qt
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 00:00:37.22, start: 0.000000, bitrate: 28428 kb/s
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(eng): Audio: aac, 48000 Hz, stereo, s16, 296 kb/s
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(eng): Video: h264, yuv420p, 1920x1080, 28168 kb/s, PAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) [buffer @ 0x1103360] w:1920 h:1080 pixfmt:yuv420p
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) [scale @ 0x1103580] w:1920 h:1080 fmt:yuv420p -> w:640 h:360 fmt:yuv420p flags:0xc0000004
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.78.5
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(eng): Video: flv, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 1000 kb/s, 1k tbn, 29.97 tbc
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, stereo, s16, 64 kb/s
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1 -> #0.0
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.1
[2/25/11 9:57:23 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2/25/11 9:57:55 AM EST]    INFO   PlaylistInputStream   admin listening to "approvals/CTW0001H264.mov"
[2/25/11 9:57:55 AM EST]    DEBUG   TranscodeInputStream   Starting transcoder: [/Library/Application Support/Subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/Volumes/HD RAID/approvals/CTW0001H264.mov] [-async] [1] [-b] [1000k] [-s] [640x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) FFmpeg version SVN-r25203-einsteinx2, Copyright (c) 2000-2010 the FFmpeg developers
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) built on Sep 26 2010 02:08:29 with gcc 4.2.1 (Apple Inc. build 5664)
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) configuration: --prefix=/Volumes/Ramdisk/ --as=yasm --extra-version=einsteinx2 --disable-shared --enable-static --disable-ffplay --disable-ffserver --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-libspeex --enable-bzlib --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-nonfree --enable-version3
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libavutil 50.28. 0 / 50.28. 0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcore 0. 9. 0 / 0. 9. 0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcodec 52.90. 0 / 52.90. 0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libavformat 52.78. 5 / 52.78. 5
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libavdevice 52. 2. 2 / 52. 2. 2
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libavfilter 1.45. 0 / 1.45. 0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Seems stream 1 codec frame rate differs from container frame rate: 5994.00 (5994/1) -> 29.97 (2997/100)
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/HD RAID/approvals/CTW0001H264.mov':
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) major_brand : qt
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) minor_version : 537199360
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) compatible_brands: qt
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 00:00:37.22, start: 0.000000, bitrate: 28428 kb/s
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(eng): Audio: aac, 48000 Hz, stereo, s16, 296 kb/s
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(eng): Video: h264, yuv420p, 1920x1080, 28168 kb/s, PAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) [buffer @ 0x1103360] w:1920 h:1080 pixfmt:yuv420p
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) [scale @ 0x1103580] w:1920 h:1080 fmt:yuv420p -> w:640 h:360 fmt:yuv420p flags:0xc0000004
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.78.5
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(eng): Video: flv, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 1000 kb/s, 1k tbn, 29.97 tbc
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, stereo, s16, 64 kb/s
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1 -> #0.0
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.1
[2/25/11 9:57:55 AM EST]    DEBUG   InputStreamReaderThread   (/Library/Application Support/Subsonic/transcode/ffmpeg) Press [q] to stop encoding
toekneebullard
Exact same problem
Postby saskwatch » Mon Mar 07, 2011 6:04 pm
I am on OSX 10.6.6. What I have to determined is that for .wmv files, the encoding works great, but for .m4v files, I get the same errors as you do.
Help?
saskwatch
Re: Exact same problem
Postby samotano » Mon Mar 07, 2011 7:15 pm
saskwatch wrote:I am on OSX 10.6.6. What I have to determined is that for .wmv files, the encoding works great, but for .m4v files, I get the same errors as you do.
Help?
Well at least I think I know where the problem lies, since I do get the intermdiate wav but not the mp3. So I am focusing on the lame step. Do you too get the intermediate wav?
samotano
Postby bushman4 » Mon Mar 07, 2011 8:10 pm
If you are getting a wave file written to disk then you must not be outputting to StdOut like the second half of the transcode needs you to.
Try adding a dash to the end of your stage one command.
BTW, the log you posted is of the transcoding of a MOV file, not a WMV file...
Glenn
Postby samotano » Mon Mar 07, 2011 9:32 pm
bushman4 wrote:If you are getting a wave file written to disk then you must not be outputting to StdOut like the second half of the transcode needs you to.
Glenn
I apologize. I've inadvertantly posted in the wrong topic :oops: My original topic was about problems transcoding from FLAC and is here:
http://forum.subsonic.org/forum/viewtopic.php?t=5903
samotano
Postby 3R3 » Tue Mar 08, 2011 3:06 am
Do you intend to fix the log to continue to get help for this problem or is this topic dead?
Its still about a .MOV file as of now.
3R3
