cannot access server locally
Postby ferraritmnt » Thu Mar 03, 2011 4:15 am
Hi, after the latest update I had to go through and adjust some things on my server. Now I cannot get to my SubSonic server from any local computer except for the server itself, however, if I am outside of the network there is no problem. My phone, for example works fine until I get home and it logs onto the wifi network. Any help is greatly appreciated.
ferraritmnt
Postby GJ51 » Thu Mar 03, 2011 6:45 am
Disable any DHCP services in any VOIP equipment you have. Only one device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
