I have not been able to access my subsonic server locally, on the home network, or remotely for about a week. I get an error of 503. I have uninstalled, reinstalled, turned off my firewall etc., but cannot get past this error.
Any clues?
user@myputer:/tmp$ sudo dpkg -i subsonic-4.4.deb
(Reading database ... 272093 files and directories currently installed.)
Preparing to replace subsonic 4.3 (using subsonic-4.4.deb) ...
start-stop-daemon: warning: failed to kill 15924: No such process
Unpacking replacement subsonic ...
Removing any system startup links for /etc/init.d/subsonic ...
/etc/rc0.d/K99subsonic
/etc/rc1.d/K99subsonic
/etc/rc2.d/S99subsonic
/etc/rc3.d/S99subsonic
/etc/rc4.d/S99subsonic
/etc/rc5.d/S99subsonic
/etc/rc6.d/K99subsonic
Setting up subsonic (4.4) ...
Installing new version of config file /etc/default/subsonic ...
Adding system startup for /etc/init.d/subsonic ...
/etc/rc0.d/K99subsonic -> ../init.d/subsonic
/etc/rc1.d/K99subsonic -> ../init.d/subsonic
/etc/rc6.d/K99subsonic -> ../init.d/subsonic
/etc/rc2.d/S99subsonic -> ../init.d/subsonic
/etc/rc3.d/S99subsonic -> ../init.d/subsonic
/etc/rc4.d/S99subsonic -> ../init.d/subsonic
/etc/rc5.d/S99subsonic -> ../init.d/subsonic
Started Subsonic [PID 16293, /var/subsonic/subsonic_sh.log]
Processing triggers for ureadahead ...
user@myputer:/tmp$ sudo apt-get remove subsonic
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED:
subsonic
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 0B of additional disk space will be used.
Do you want to continue [Y/n]? Y
(Reading database ... 272092 files and directories currently installed.)
Removing subsonic ...
Selecting previously deselected package subsonic.
(Reading database ... 272088 files and directories currently installed.)
Unpacking subsonic (from subsonic-4.4.deb) ...
Started Subsonic [PID 16429, /var/subsonic/subsonic_sh.log]
user@myputer:/tmp$ sudo apt-get --purge remove subsonic
subsonic*
Purging configuration files for subsonic ...
