Login issues
Login issues
Postby GodsLeftNut » Fri Mar 04, 2011 9:18 pm
Hey everyone! I just installed subsonic and for some reason it doesn't let me sign in initially. The admin login doesn't seem to work...Its still:
User: admin
Pass: admin
Right?
Also that red text on the login page isn't there. That getting started information.
GodsLeftNut
Postby donpearson » Fri Mar 04, 2011 9:30 pm
Try to uninstall and reinstall... see if that helps.
But make sure you remove all the files off your system before you reinstall.
Facebook Group:
donpearson
Postby GodsLeftNut » Fri Mar 04, 2011 9:43 pm
I tried that twice and I even went back a version to see if that worked. No success...
GodsLeftNut
Postby donpearson » Fri Mar 04, 2011 9:45 pm
Can you tell us more info, like what OS?
Facebook Group:
donpearson
Postby GodsLeftNut » Fri Mar 04, 2011 10:00 pm
No problem. Im on windows 7 64bit using the newest firefox. Do you need computer specs? Also this would be my second server. The first one is running on a private network at my school.
GodsLeftNut
Postby GJ51 » Sat Mar 05, 2011 12:42 am
Delete the C:\Subsonic directory and reinstall.
Postby donpearson » Sat Mar 05, 2011 12:45 am
donpearson wrote:Try to uninstall and reinstall... see if that helps.
As i said to do that, but he said he done that twice.
Facebook Group:
donpearson
Postby GJ51 » Sat Mar 05, 2011 1:21 am
If you manually delete the C:\Subsonic directory and reinstall SS it will reset everything to default.
