Subsonic 4.4 Windows 7 Player Fails
Postby sekhu » Fri Mar 04, 2011 11:40 pm
I've got aproblem with trying to stream video with subsonic. I've followed the following guide:
http://forum.subsonic.org/forum/viewtopic.php?t=2528 (which refers to 3.8)
There is another guide I tried, same forum, linking to the one above, but that didnt work either.
Basically I try to run the video file, and it doesn't work. I click on the video file ont he list on the left, it loads up the cover art, I clcik the cover art. It loads the cover art again only the right size. Then I click on play and nothing happens :(
Can anyone help? I have the altest Flash player 10.x.x.x, using Opera 11, FF 3.8 ( I think is the latest it might be lower), even tried ie8, and no luck. I'm not sure where I'm going wrong.
I've tried CCCP codec pack, I've tried KLite Codec Pack, no luck. I've portforwarded, used https, nothing. I've asked my firne dto try he can login to me, the cover art shows up, but the video does not play :(
Help!
thanks in advance
sekhu
Postby GJ51 » Sat Mar 05, 2011 12:39 am
Thiose forum posts you linked to were kludges used before video was incorporated into Subsonic by the developer. Version 4.4 will play video without any tweaking. I'd suggest you uninstall Subsonic and Java, reboot your computer, then do a clean install of the latest java and then Subsonic 4.4.
Follow these instructions for Windows:
Disable any DHCP services in any VOIP equipment you have. Only one device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
If your still having problems. Clear browser cache. Reboot the server. If that doesn't work, uninstall/reinstall Java. If still no joy, try reinstalling SS right over the top of the current SS using the latest version.
Postby sekhu » Sat Mar 05, 2011 6:38 am
thank you for the prompt response. Following your tips and links I was able to successfully share my video files and stream them.
Some of the videos I've made are 720p. I was wondering what kinda toll this woudl take?
My pc specs:
GTX560Ti
Core2Quad Q8200 2.8Ghz (oc from stock 2.3)
4GB DDR2 PC 6400 RAM
12mbps down/1.5mbps up
I guess I should stick to converting to avi perhaps, or it auto transcodes anyway right?
sekhu
Postby GJ51 » Sat Mar 05, 2011 3:52 pm
Subsonic is inherently a "weakest link" system. You have to consider all the links in the chain from end to end to determine what your particular limiting factors will be. I preformat all my video into mp4 or flv so that they can be played in JW Player without being transcoded. Transcoding takes a lot of CPU power and can become a bottleneck on even powerful CPU's as ffmpeg only utilizes one core per stream.
The other limitation is connection speed - at BOTH ends, You can have all the download speed in the world, but usually the bottleneck is the upload speed from the server hosting SS.
Subsonic is a truly remarkable application that runs on an incredibly wide array of hardware and software. Unfortunately, many users don't understand the limitations of their own configurations. This can lead to unrealistic expectations, or worse yet, the inability to have the patience to maximize the REALISTIC performance achievable with SS.
I have actually watched blue ray quality video on a state of the art laptop over a fios internet connection. I had to give it a couple minutes to buffer, but after about 5 mins. it played through without any glitches. The key is getting the right setup on the right hardware over good internet connection speeds.
