Error installing on Ubuntu 11.04a3
Postby roberj13 » Sat Mar 05, 2011 3:00 pm
I am trying to install the subsonic desktop client on ubuntu 11.04a3 and am gettinh this error on install.
The package is of bad quality.
The installation of a package violates the quality standards isn't allowed. This could cause serious problems on your computer. Please contact the person or organization who provided this package and include the details beneath.
Details:
Libtain check results for subsonic-4.4.deb:
E: subsonic file-in-etc-not-marked-as-conffile /etc/init.d/subsonic
W: subsonic: unknown-section Multimedia
E: subsonic: no-copyright-file
W: subsonic: init.d-script-not-marked-as-conffile /etc/init.d/subsonic
roberj13
Postby juelze » Tue May 03, 2011 2:09 pm
I'm having the same issue with 11.04 (64 bit).
juelze
Postby edina » Tue May 03, 2011 6:43 pm
me to :(
edina
Postby juelze » Mon May 09, 2011 7:01 pm
Sindre, are you able to add any input on this?
juelze
Postby juelze » Wed May 11, 2011 8:07 pm
*BUMP*
juelze
Re: Error installing on Ubuntu 11.04a3
Postby spookybathtub » Tue Aug 23, 2011 3:50 am
I have this problem too. I have a clean install of Ubuntu 11.04. I downloaded the Subsonic installer today and opened it with "Ubuntu Software Center". I get "This package is of bad quality. Details: The package doesn't provide a valid Installed-Size control field. See Debian Policy 5.6.20."
Hardware:
AMD X2 260 (64-bit)
4GB RAM
spookybathtub
Postby lars mars » Fri Aug 26, 2011 3:38 am
ok - i am completely new to subsonic, but thats exactly what i am looking at :(
so, is there any solution for it yet? i am a happy kplaylist user thought trying sth new - looks good in the demo etc.... looking at that just trying to install is a bit of a downer!
than again there must be some kind of solution! otherwise, why do i get subsonic recommended!?
the documentation is not exactly great - i know, it is nowhere (same with kplay)....
but hello, sb out there to give us a hint about this install error... its supposed to be all smooth there and than you start fiddling....
lars mars
Postby sindre_mehus » Fri Aug 26, 2011 10:38 am
lars mars wrote:the documentation is not exactly great - i know, it is nowhere (same with kplay)....
The installation instructions for Ubuntu are here: http://subsonic.org/pages/installation.jsp#debian
Last time I checked it installed fine on Ubuntu 11.04
Hope this helps,
Postby lars mars » Fri Sep 23, 2011 2:18 am
Hope this helps,
took some fiddeling around, but worked - thx. now i have my issues still with getting it stable to run (playing around with memory allocation anywhere between the "standard" 120mb and 2048mb) - seems to be hit and miss, sometimes it starts up just fine (once it does - it runs without prob), other times i just get "out of memory" errors??? nothing changed in my setup. kinda annoying still.
beside all that - one other major issue i have with ss, when it is running - why the heck can't i search by genres???? i had that with aba for kplaylist, he finally implanted the feature, it can't be that hard - its allready there, just implement into the search options (maybe it is - i have no clue about programming!) but it is a major set-back for big collections!
beside all this, i really like subsonic. yes, i do - i wouldn't bitch around, if i dont care ;)
and while we are at bitching around - is there an easy way to change the width of the "columns" - like left-right-center???
anyway, so far - nice job! i like it....
thx, keep it up,
lsdeep
lars mars
