A Network error occured, retrying.
Postby Junglist » Sun Mar 06, 2011 4:57 am
I find it less than amusing that this worked flawlessly until I donated, at which time it immediately ceased to function.
Status: Successfully forwarding port 80.
Status: junglist.subsonic.org responded successfully.
I can no longer connect on my android device. It just does nothing. It was working fine earlier, now it does nothing. I have tried rebooting, restarting the services... linking directly to my IP, nothing works.
EDIT: Mere moments after posting this, I checked the phone again and it magically works all the sudden. Is there a link to set this up with Google Public DNS as I changed NOTHING and it started working. I assume it has something to do with the subsonic DNS on their end.
Junglist
Postby GJ51 » Sun Mar 06, 2011 7:42 am
You can just use your external IP:port#
e.g. http://98.117.185.5:8084/
