Shuffle Play is not working at all. Android (HTC EVO)
Postby petchulio » Mon Mar 07, 2011 2:16 am
I just followed the full instructions on setting up Subsonic on my PC running Windows 7 and downloaded and installed the Android app as well on my HTC EVO. I can play individual songs just fine from my library but Shuffle Play does not work at all from my computer, it just tells me "Playlist is empty" on the Player screen when I press it. Shuffle Play works fine if I use it on the Demo Server but not mine. Does anyone have any idea why that would be and how I could go about fixing it? Thank you.
petchulio
Postby bushman4 » Mon Mar 07, 2011 3:32 pm
Regenerate the Search Index. I believe that the search index is used to build the random playlist.
Settings->Search->Update Search Index
HTH,
Glenn
Postby petchulio » Mon Mar 07, 2011 10:56 pm
That worked perfectly! Thank you so much! I wasn't even aware that the shuffle came from there. I guess it hadn't scanned yet since it was set to do so at 3 AM daily. That would explain why it wouldn't work.
petchulio
Postby bushman4 » Wed Mar 09, 2011 3:48 pm
No problem, glad I could help.
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: No registered users and 38 guests
