subsonic login page randomly popping up. Help!
Postby kvrdave » Mon Mar 07, 2011 5:58 am
I downloaded subsonic yesterday. Since that time my browser has been randomly redirecting to the subsonic login page (the admin/admin one). For example, if I go to facebook or photobucket, I put in my login stuff, hit the login button, I will log in, then suddenly be directed to the subsonic page. Or, if I go to some random site like dealnews.com I am suddenly redirected to the subsonic login page. Happens in IE and also happens in Firefox.
I'm on a 32 bit Vista machine.
Any ideas? Can't seem to find any incidents of this happening to anyone else, but it may just be a tricking thing to search for.
kvrdave
Postby alphawave7 » Mon Mar 07, 2011 6:15 am
Had this happen on a friend's install, using the default port 80. Try another port.
Postby kvrdave » Mon Mar 07, 2011 7:25 am
Thanks, I will try that. The settings area says "If your router can't be configured automatically you can set it up manually. Follow the instructions on portforward.com. You must forward port 80 to the computer running the Subsonic server. "
Will any number port be fine and is the above incorrect that it must be port 80?
kvrdave
Postby GJ51 » Mon Mar 07, 2011 8:55 am
Disable any DHCP services in any VOIP equipment you have. Only one device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it and these are also the default ports on WHS. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Postby 3R3 » Tue Mar 08, 2011 3:53 am
I'd love to see a link to that, a nonstandart port that crashes SS? Interesting if reproduceable.
That strange behaviour was because both your browser was sending on port 80 and subsonic listening on 80. So from time to time collisions occur and people wonder. Keep port 80 (and a few others, google for standard ports) free at all cost if you want to use the pc on that network for other things beside subsonic.
3R3
Postby GJ51 » Tue Mar 08, 2011 4:42 am
It wasn't something I observed directly, but one user I was helping was set up in the 5000 range I think. Don't ask me where the link is as the thread is a few months old now. I try to give information that I know works. I've never had, nor have I ever heard of anyone else having any issues setting up ports in the 808x range. I'm sure there are untold numbers of other port numbers that will work just as well, but I prefer to stick with what experience has taught me that doesn't present new problems that I've not encountered before.
I'm no IT expert, I'm just a user. I'm not too concerned with the "why it works" rather I'm all about "this is what I found that works."
Postby kvrdave » Tue Mar 08, 2011 6:16 am
Thanks. I ended up purchasing the port fowarding software. From within subsonic, I saw where to uncheck the "automatically configure" but for the life of me I could never see a way to manually put in another port, such as 8080 or anything else. I changed the port forward software to 80 and it works, but I will continue to have the same intermittent problem.
So from settings>network I get the uncheck, but where do I find a place to manually put in another port?
Thanks much for this help.
kvrdave
Postby GJ51 » Wed Mar 09, 2011 2:15 am
I guess you must have just missed this part. :wink:
In the court room the objection would be phrased, "Asked and answered, your honor."
We're a bit more forgiving here, but within limits. 8)
Postby kvrdave » Thu Mar 10, 2011 5:48 am
Thanks a bunch for your help. I need to slow down and read, but it doesn't seem to be in my nature. :wink:
kvrdave
Postby GJ51 » Thu Mar 10, 2011 7:32 am
This is one project where the hard way IS the easy way. Unless you're just plain lucky, you really need to understand what needs to be done if you want this to work and be stable. Home networks only get more complicated as they get older, this is a great project to learn needed skills that will server you well into the future. Take your time, it'll be worth it.
Users browsing this forum: No registered users and 48 guests
