Network / router settings help
Postby capsize » Mon Mar 07, 2011 5:12 pm
In my subsonic network settings I am seeing that my portforward status is Successfully forwarding port 5000, however the status for accessing my server is XXX.subsonic.org is registered, but could not connect to it. (connectTimeoutException).
i can connect using localhost, however trying to connect remotely via my subsonic.org url isnt working.
Any help would be great.
capsize
Postby 3R3 » Tue Mar 08, 2011 3:13 am
Your error indicates the subsonic server does not respond in time, either due to not being able to reach your machine in a LAN behind a router or it was offline when you tried to reach it. Have you verified the port being open with an external online port checker too?
3R3
Postby GJ51 » Tue Mar 08, 2011 3:17 am
Disable any DHCP services in any VOIP equipment you have. Only one device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it and these are also the default ports on WHS. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
