Transcoding at lower bit rate
Postby jerryyyyy » Wed Mar 09, 2011 12:51 am
Hi, I see that the default bit rate for transcoding from WAV to MP3 is 256 bps. I would like to see if I can go 128 to reduce bandwidth requirements is marginal areas for streaming to an Android device.
I cannot seem to find how to manipulate this conveniently.
Thanks in advance.
jerryyyyy
Postby GJ51 » Wed Mar 09, 2011 1:46 am
In the Android app, tap on settings, set max bitrate to anything you like.
Postby jerryyyyy » Wed Mar 09, 2011 7:47 pm
GJ51 wrote:In the Android app, tap on settings, set max bitrate to anything you like.
Thanks very much. Normally I have good mobile 3G service here, but there are a few holes that would be best dealt with at lower bit rate.
jerryyyyy
