Weird Problem With Installation
Postby sekhu » Thu Mar 10, 2011 1:49 pm
I've had to reinstall Subsonic 4 or 5 times now. Basically it works fine for w while then when I log in a random day it will remove the play/playlist/add buttons from the side of the tracks or video files.
I dont know why this is, but it has happened eveytime I re-enter my license details - it's almost as though instead of adding features it's removing them when I enter the license. I could be off base, but 4 installs is not a good sign.
Also the easy to use webaddress which is part fo the paid feature does not work correctly for me. My ports are correctly forwarded according to canyouseeme.org and the subsonic install in networking, but the easy to remember address says:
Status: <name>.subsonic.org responded successfully, but it could not authenticate
Any suggestions on what I can do to troubleshoot? I delete all the subsonic folders each time I do an install including the c:\subsonic.
thanks
EDIT: Using win 7 x64 as my OS.
sekhu
Postby GJ51 » Thu Mar 10, 2011 11:51 pm
Disable any DHCP services in any VOIP equipment you have. Only one device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
If your still having problems. Clear browser cache. Reboot the server. If that doesn't work, uninstall/reinstall Java. If still no joy, try reinstalling SS right over the top of the current SS using the latest version.
Postby sekhu » Fri Mar 11, 2011 6:25 am
hi gary
i've done all of that. honestly - but the problem is the installation for sure. I'm not sure why it's getting corrupted, or maybe it's not is there way to check for the integrity of the files?
I;m in a windows 7 x64 environment, and the play buttons have just disappeared again once more - I haven't added the license key this time. Other users are seeing the same thing.
I'll reinstall java etc and see ifthat helps but I shouldn't be doing this so often. Any ideas on what it might be? I've done a disk check and it passed, I've defragged, and ran a registery checker and cleaned up any errors. Not sure what else I can do. Only a clean install will fix the problem :(
But to answer your other questions - reinstalled Java, reinstalled Subsonic over the top of the previous installation, can see my external ip, can log in via it, can use https and http, ports are forwarded, canyouseeme sees the ports, other users can log in - everything works, excepo tthe play button disappears fromt eh side of the tracks and video files. Also the player doen't play anything when this happens
thanks
sekhu
Postby bushman4 » Fri Mar 11, 2011 12:47 pm
You don't have a corrupt install... you are inadvertantly turning party mode one.
Party mode removes the "Play" button so that you don't overwrite your entire playlist in the middle of a party. You can only queue files in party mode.
And since videos cannot be "queued" videos are a complete fail in party mode.
So just shut off party mode for the account you are logging in as, and you will get your play buttons back.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby sekhu » Fri Mar 11, 2011 1:35 pm
omg lol i've been uninstalling it and reinstalling cuz i had party mode on? Thank you so much for your help it worked!
sekhu
Postby bushman4 » Fri Mar 11, 2011 1:46 pm
If I had not done it myself in the past (and not wanted to recreate a 30+ person user database) I never would have known.
I know, I know, you see a checkbox labelled "Party Mode" and think "Hey, I'm a happenin' kind of guy; I like to party" and you check it off.
And an hour later you go to replace your playlist completely and think "why do I have no Play button? Am I not a PLAYer?"
:wink:
Glad I could help,
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Fri Mar 11, 2011 3:52 pm
Good call Glenn. I should have recognized this too, it's been a while since we last ran into this.
Postby 3R3 » Fri Mar 11, 2011 9:13 pm
Thats so good to see it resolved. I didnt have the slightest idea of what it might have been. Not been using the party mode in RL though :)
3R3
Postby sekhu » Sat Mar 12, 2011 1:25 am
how does party mode work then - and what does it actually do? I mean the player doesnt work, who has control? It's a weird feature, but then I dont know how to use it so it must seem like that to me.
thanks again, was racking my brain for ages
sekhu
Postby GJ51 » Sat Mar 12, 2011 1:36 am
You just add tracks to the playlist and then use the controls on the player bar.
Postby sekhu » Sat Mar 12, 2011 2:42 am
hmm i think i'll leave it then. cuz when i dont see how I can add files, when I click party mode it....wait sO I add the files BEFORE i click party mode and then click play or something like that? Because once in party mode it doesn't allo wme to play anything. But when in party mode I;m just wondering, what it does, can two accounts watch the same thing together? Like I add the files, then in party mode I say everyone ready or wahtever and hit play? Is that how it works?
sekhu
Postby GJ51 » Sat Mar 12, 2011 4:54 am
Party mode really only works if you already have several predefined playlists and you don't want others messing around with you system. For most users, it isn't of much practical use. the best way to learn all the features of Subsonic is to test each screen to see what it does. Once you become more familiar with the intyerface, it all becomes pretty easy to figure out. Just be patient and try everything.
Users browsing this forum: No registered users and 38 guests
