registered but can't connect
Postby epicurus » Thu Mar 10, 2011 8:18 pm
I am running subsonic on xubuntu connected via ethernet. I have forwarded ports 4567 and 5431, which are open. I can connect locally to subsonic. However I cannot connect outside my network. When I check the automatic connect box. It states beneath it that: "___ is registered but cannot connect to subsonic.org (nohttpresponseexception)." I have scoured the forums, and have fiddled with this for far too long. I am on the trial period and would like this to work, because it seems very useful and just a good product. Thanks for your help ahead of time.
epicurus
Postby bushman4 » Thu Mar 10, 2011 8:22 pm
Go to http://www.canyouseeme.org/ and enter the HTTP port that you are running subsonic under and see if it shows open. I bet it doesn't.
Does it work from a different PC on the same LAN?
If it works on the subsonic server but no place else, it is probably a firewall on the Subsonic Server causing the problem.
If it works on the Subsonic Server and on another computer that on the same local LAN as the Subsonic Server but DOES NOT work from outside the LAN then it is NOT a firewall on the Subsonic Server, but rather is a problem with the port mapping on your router.
More info...
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby epicurus » Thu Mar 10, 2011 10:01 pm
Works on diff. computer but not outside, I am nearly certain both ports are open.
Thanks though
epicurus
Postby GJ51 » Thu Mar 10, 2011 11:53 pm
Disable any DHCP services in any VOIP equipment you have. Only one device per network should handle DHCP assignments.
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Postby epicurus » Fri Mar 11, 2011 3:56 am
Thank you for your reply, gary it is appreciated. I reinstalled java fresh. I double rechecked all my ports, all are open. Still cannot connect outside my network. Works fine inside. I have a static ip, everything there has been good and gold for quite some time. Does anyone know if subsonic is firewall-ing ports 4567, and 5413? Or is there some hidden config file that I should change for linux? Any ideas are welcome, but I will say again the ports are open.
Pic is not displaying so feel free to us the link
epicurus
Postby epicurus » Fri Mar 11, 2011 4:04 am
I found this in the subsonic.log maybe it could help:
[2011-03-10 20:38:10,864] INFO NetworkService - Deleted port mapping for port 4567
[2011-03-10 20:38:10,919] INFO NetworkService - Deleted port mapping for port 5431
[2011-03-10 20:39:38,273] INFO NetworkService - Deleted port mapping for port 4567
[2011-03-10 20:39:38,327] INFO NetworkService - Deleted port mapping for port 5431
and this in subsonic_sh.log
Subsonic running on: http://localhost:4567/
                and: https://localhost:5431/
20997 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
21045 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
21200 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
Could it have something to do with not detecting rmi registry? Lastly I am using an actiontec q1000 router. The reason I am using ports 4567 and 5431 is that I cannot get other more convenient ports to open. I have tried even with the firewall deactivated and I can only get a couple ports that are I open - I got these by dropping the firewall and scanning my network for open ports. Either Qwest (the isp) is blocking them or something else, which I have not thought of.
Thanks again for any help.
epicurus
Postby GJ51 » Fri Mar 11, 2011 5:59 am
Humor me and try setting up JUST http access on port 8081. I have an Actiontec router, let me know if you need help setting up port forwarding on it.
