Installing on a Windows Home Server Machine
Postby tomkiki1 » Wed Mar 16, 2011 9:46 pm
First post to this form, I have searched for an answer but can't find one, so here goes.
I just set up a Home Media Server on my home network, the OS is Microsft Home Server. I have successfully moved all my media files to the server, my Squeezebox is working, and want to get the audio files off of my computer. Unfortunately my SUBSONIC Droid Ap is pointing to the computer and not my server.
My question is how do I set up Subsonic so it runs on my sever. I think I need to add an add-in to the server. This would be an installation program with an .msi file extension.
Any help would be appreciated.
tomkiki1
Postby rickeo » Wed Mar 16, 2011 11:47 pm
I have had Subsonic running on my WHS for at least 2 years now without issues. No Add-Ins needed.
Just RDP into the WHS box or hook up a keyboard, mouse and display and install Subsonic as you would on any Windows machine.
rickeo
Postby Leonard26 » Wed Mar 16, 2011 11:51 pm
Like tomkiki1 said, you'll need to RDP into the Homeserver.
If you want to use the xxxx.homeserver.com url to access your subsonic outside your network, you can set that up to. You'll need to use the .war installer and use a server like Tomcat.
Setting up IIS can be a bit of a pain, as you don't want to hose your homeserver, but it's not that bad. There are a few guides to help you on your way... happy googling!
Leonard26
Postby GJ51 » Thu Mar 17, 2011 12:00 am
You can just do the normal Windows install. Just set up SS opn a different port. You can access my whs logon page using http://maplegrove.homeserver.com:8083
no WAR installer or IIS hassles required :lol:
Postby JWBokx » Thu Mar 17, 2011 7:50 am
On my server the same, just installed the windows version.
It's running without any problem for a long time.
If you want access from outside your home, don't forget to make a portforward on the port you want to use to you homeserver.
JWBokx
Postby Leonard26 » Thu Mar 17, 2011 1:19 pm
GJ51, you're totally correct, you don't have to use the war installer.
I did however since I can get out of my work firewall on any ports other than 80 and 443....
Cheers!
Leonard26
Postby GJ51 » Thu Mar 17, 2011 4:34 pm
All you need to do is set up the port forward properly on the router. However, I always recommend, "if it ain't broke, don't fix it."
Postby tomkiki1 » Fri Apr 01, 2011 10:39 pm
Thanks for all the replies, sorry on the delayed thanks, been on vacation and out of town.
Anyway, I got Subsonic installed on my server. Unfortunately I can't interface the Localhost at subsonic to finish the set up. I have forwarded the ports (80, 8080, 4040) to the server. when I try to open http://localhost/ I get the Acer easyStore Home Server page. Can any one help me with changing the localhost so I can finish the set up?
Again thanks a million for the quick help you gave me.
tomkiki1
Postby GJ51 » Sat Apr 02, 2011 12:52 am
Use Remote desktop connection to get into the WHS. Then right click on the Subsonic tray icon to open the Subsonic Control Panel or to Open SS in the local browser. WHS uses 80 and 443 as the default to it's remote access webpage, therefore, set SS to something other, such as 8080 and 440 for SSL.
Postby tomkiki1 » Mon Apr 04, 2011 2:20 am
Thanks Gary,
Unfortunately I am still having troubles. I am in the Subsonic Control panel
on the Status tab it shows the following
Service Status: Running, Auto-start.
Started: today date is shown
Memory Use: 5MB
Error Message: Address already in use. Please change port number
Server address: http://localhost/
Under the Settings TAb
Port Number: 8080 (have tried 4040)
check box is on for Enable https on port: 4040 (have tried 443)
Memory Limit (MB): 100
Context Path: /subsonic. ( have tried '/music' and '/', neither worked)
I'm sure the fix is easy but I sure as heck can't figure it out.
tomkiki1
Postby GJ51 » Mon Apr 04, 2011 2:43 am
OK, let's try:
Open SS Control Panel, stop the service, click on Settings tab,set port # to 8080, set https port to 440, set Memory limit to 256, context path to /
Make sure port forwarding sends 8080 and 440 to the SS host computer's internal ip address.
Easy fix - just disable https.
Save settings, click on Status tab, restart the service.
Postby tomkiki1 » Mon Apr 04, 2011 1:07 pm
Thanks Gary, I got further, but not success yet. I got the following error message when trying to load http://localhost:8080/ into my browser.
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
I really do appreciate your help.
tomkiki1
Postby GJ51 » Mon Apr 04, 2011 3:42 pm
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
If your still having problems. Clear browser cache. Reboot the server and the router. If that doesn't work, uninstall/reinstall Java. If still no joy, try reinstalling SS right over the top of the current SS using the latest version.
Default Transcoding for video:
Postby tomkiki1 » Mon Apr 04, 2011 10:49 pm
Thanks Gary,I do appriciate the time you have taken to write this all out.
Hopefully I will get it up and running soon. I'm missing my subsonic.
tomkiki1
Postby tomkiki1 » Sun Apr 10, 2011 4:17 am
No joy yet.
My ports are forwarded 8080 and 440. I can see them with the "can you see me" web site. My Ip address is static, and at the higher end of the range. Subsonic ap is running on the server. I just can't get to the subsonic website. I have tried my outside ip address http://98.XXX.XX.178:8080, will not connect. I have tried my Http://servername.subsonic.org, will not connect.
I flushed my browser cache, rebooted, rebooted the router, reinstalled subsonic,
What is left to try.
Tom
tomkiki1
Users browsing this forum: Google [Bot] and 28 guests
