Subsonic App no longer working
Postby janth1 » Thu Mar 17, 2011 3:19 am
Up until today Subsonic has been working great. I made no changes but i was unable to connect to my server remotely either via the website or from my Subsonic Android App.
Problem Description: Unable to connect remotely to my subsonic music server
Server shows the following error: Status: justindanthony.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
Android App error: Connection failure: Didn't understand the reply. Please check server address
Troubleshooting Steps: I have tried using a different port, assigning a static IP
Playback Application and version: Subsonic Android Application
Subsonic Version: 4.4 (build 2172) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_24, Windows 7 (29.4 MB / 51.2 MB)
Hardware Platform: Windows 7
Java Memory Limit: 40 MB
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines:
[3/16/11 10:57:16 PM EDT] INFO DaoHelper Checking database schema.
[3/16/11 10:57:16 PM EDT] INFO DaoHelper Done checking database schema.
[3/16/11 10:57:17 PM EDT] INFO SearchService Automatic index creation scheduled to run every 1 day(s), starting at Thu Mar 17 03:00:00 EDT 2011
[3/16/11 10:57:17 PM EDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Mar 16 23:02:17 EDT 2011
[3/16/11 10:57:23 PM EDT] INFO NetworkService Successfully forwarding port 80 and port 443.
[3/16/11 10:57:59 PM EDT] INFO VersionService Resolved local Subsonic version to: 4.4
[3/16/11 10:58:00 PM EDT] INFO VersionService Resolved latest Subsonic final version to: 4.4
[3/16/11 10:58:00 PM EDT] INFO VersionService Resolved latest Subsonic beta version to: 4.4.beta1
[3/16/11 11:02:17 PM EDT] INFO PodcastService Starting scheduled Podcast refresh.
[3/16/11 11:02:17 PM EDT] INFO PodcastService Completed scheduled Podcast refresh.
[3/16/11 11:02:18 PM EDT] INFO NetworkService Deleted port mapping for port 8081
[3/16/11 11:02:19 PM EDT] INFO NetworkService Deleted port mapping for port 443
[3/16/11 11:04:54 PM EDT] INFO NetworkService Successfully forwarding port 8081 and port 443.
janth1
Postby GJ51 » Thu Mar 17, 2011 6:22 am
Go to http://www.canyouseeme.org/ enter your SS port number and click the Check box to be sure the Subsonic port is open.
"Java Memory Limit: 40 MB" - Open SS Control Panel and make sure memory is set to at least 100MB
Postby janth1 » Thu Mar 17, 2011 5:57 pm
Thank you for the help. When you mentioned the port number website that triggered me to think about my machine.
Come to find out for some reason my firewall on my Windows 7 box stopped accepting traffic, so i changed to port to 8081 and configured the firewall for that new port and everything is working great again.
Thanks again.
janth1
Postby GJ51 » Thu Mar 17, 2011 8:54 pm
As my home network continues to expand and become more complex, I find it increasingly important to do long term logical planning to keep everything easier to administer.
Just a suggestion for home network layouts:
Server 1 - 192.168.1.240 - http port 8080 - https port 440
Server 2 - 192.168.1.241 - http port 8081 - https port 441
Server 3 - 192.168.1.242 - http port 8082 - https port 442
Skip 8083,443 to avoid the 443
Server 4 - 192.168.1.244 - http port 8084 - https port 444
and so on as needed. It really helps when your setting up or editing your router when your assignments are well thought out and logical.
Just food for thought.
