Search has never worked for me and now random doesn't...
Postby unamused » Thu Mar 17, 2011 1:49 pm
I've been loving and using Subsonic for around a month or so, and the search function has never worked for me, neither on the browser interface nor the Android app.
I've manually updated the search index and the log tells me it does, but no luck whatsoever when I try to search. I'm stumped. I've looked for solutions here, but to no avail.
Now, another issue... when I took a look this morning at the browser (and Android interface) the Random feature doesn't work any more. What the heck? No idea at all what is going on there. I use that feature nearly every day, so its rather disappointing.
Version 4.4 (build 2172) – February 6, 2011
Server jetty-6.1.x, java 1.6.0_24, Windows 7 (37.7 MB / 60.5 MB)
thanks for any help.
unamused
Postby GJ51 » Thu Mar 17, 2011 4:18 pm
http://www.java.com/en/download/faq/java_win64bit.xml
Then, just try reinstalling SS right over the existing install. This will retain your current settings and may fix the issue.
Postby unamused » Fri Mar 18, 2011 1:56 pm
ok, this is totally bizarre, but I didn't do anything and suddenly today, both the random and search work, for the first time ever!
strange, but cool.
unamused
Postby bushman4 » Fri Mar 18, 2011 2:34 pm
Both are very tied to the indexing process... sounds like last night's index update worked finally.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
