Able to connect over wifi, connection timeout errors over 3G
Postby an_otter » Sat Mar 19, 2011 6:11 pm
Any ideas? I'm able to connect through my mobile (Android 2.1) via wifi without a hitch, but 3G the connection errors out attempting to connect.
an_otter
Postby GJ51 » Sat Mar 19, 2011 8:13 pm
That would indicate that you do not have the ports open to get to the server from outside your network.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby an_otter » Sat Mar 19, 2011 8:32 pm
Just to clarify, I've checked connectivity on an network outside of the one this setup is on, and I'm able to reach it on my mobile via WiFi, but not 3G.
an_otter
Postby GJ51 » Sun Mar 20, 2011 3:01 am
What are you getting on a 3g speedtest?
Postby an_otter » Mon Mar 21, 2011 4:33 am
Tests vary, but 102.5kbps average.
an_otter
Postby GJ51 » Mon Mar 21, 2011 3:26 pm
That's pretty low, even for 3g. At 100 kbps you'll have trouble as most music is at least 128kbps. Try connecting to the demo server to see if it works any better. With 100kbps speed your best bet would be to try a 64kbps ogg file.
Postby an_otter » Mon Mar 21, 2011 4:48 pm
It seems to swing from 225kbps to 75kbps, but be that as it may, should it still be timing out during initial connection? No music files have been attempted to be streamed yet.
Do you perhaps have a link to the demo server?
an_otter
Postby GJ51 » Mon Mar 21, 2011 5:53 pm
http://demo.subsonic.org
Username: android-guest
Password: guest
Postby an_otter » Mon Mar 21, 2011 6:06 pm
Connects without a hitch and streams pretty fluidly, nice. So it's gotta be a routing/forwarding issue with my setup. I'll try some things and check back.
an_otter
Postby an_otter » Mon Mar 21, 2011 10:42 pm
Yeah, I've had others attempt to connect to the server now, from their locations, and it's not connecting for them either, WiFi or not. Has to be a port/ip issue.
Could you direct me to any good static ip/port forwarding walkthrough for Macs? I glazed through this: http://forum.subsonic.org/forum/viewtopic.php?p=8999 but it doesn't cover much.
an_otter
Postby GJ51 » Tue Mar 22, 2011 1:46 am
The most helpful information I have is already up on my second post on this thread. The port forwarding is done on the router. The best information is available on the manual for your particular router. They are all slightly different. Most router manuals are available online. Just do a google for "myrouter manual pdf" and you should be able to find it.
