Setting up subsonic for external access
Postby jonlai9 » Sun Mar 20, 2011 6:30 pm
I'm trying to setup my subsonic server so that I can access it externally. I'm using dyndns right now but if it works I plan to direct it to a domain name I own.
I port forwarded the subsonic port on my router but subsonic keeps telling me the port is not forwarded. I can access the server fine if I use the XXX.subsonic.org path, but not when I use http://IP_ADDRESS:PORT or the dyndns address.
When I try to access it, I get this error:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/
Powered by jetty://
What am I missing? Thanks.
jonlai9
Postby gamezonline » Sun Mar 20, 2011 8:06 pm
What version are you running? (windows,mac,etc)
If you running windows try this, open subsonic contral panel, on the settings tab where it says context path. You will have to use that path if one is set there example
http://IP:PORT/PATH
or
http://192.168.1.x:4040/subsonic
if its just a "/" set as the context path then its just
http://IP:PORT/
gamezonline
Re: Setting up subsonic for external access
Postby GJ51 » Mon Mar 21, 2011 12:20 am
jonlai9 wrote:I'm trying to setup my subsonic server so that I can access it externally. I'm using dyndns right now but if it works I plan to direct it to a domain name I own.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/
Powered by jetty://
If you can access using the xxxx.subsonic.org address, but nit the ip:port address, then the ip:port address you're using is not correct. The fact that your getting through frrom outside with the subsonic.org address indicates that the proper port is open. Verify the port# and ip address both on your router and the SS Control Panel.
Postby jonlai9 » Mon Mar 21, 2011 12:33 am
Nevermind, got it working now. Thanks.
jonlai9
