[Android] Bug with songs w/ same name in id3 tag
Postby maxslug » Wed Mar 23, 2011 5:31 am
Problem : I'm playing an audio book that has very few ID3 tags. The file names are in this format :
Part1_track001.mp3
Part2_track001.mp3
If I look in the ID3 fields there is only a id3v1 tag for Track Name and it lists "track001" for both of the above files. The Album name is different on the two files, "Part1", and "Part2".
In the android client, the UI correctly has the files listed separately, but when I click on Track1 / Part 2 the audio for the 1st part comes out!
Workaround : I redid the ID3 tags so that all the track names are unique.
This seems to be a bug only in the android client.
maxslug
Postby bushman4 » Wed Mar 23, 2011 1:09 pm
I agree that sounds like a bug, but fortunately Subsonic's tag editor makes that real easy to fix... click the "Edit Tags" button, and hit the "S" at the top of the Track Name column and Subsonic will suggest names for you, and most cases that works fine...
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
