[Android] Cached Music not found in offline mode
Postby steave » Thu Mar 24, 2011 8:18 am
Problem Description: Some cached files are not found in offline mode. The android application shows the folder in the list, but when I click on it, it says "no music found". I can, however, find the files on the SD card in the usual place ([sdcard]/subsonic/music/folder/).
Also, when online, they are marked with a yellow or green asterisk depending on cache state (cached/ downloaded) as expected.
Troubleshooting Steps:
Browsed to the files on the SD card -- they are there
Tried to play them in the android player -- works fine
deleted them from the phone using subsonic app and recached them -- same behavior
deleted from phone and downloaded to phone -- same behavior
Playback Application and version: latest subsonic android client
Server Setup: Subsonic 4.2 on QNAP NAS with standard settings (standalone JAVA server with Sun ARM Java runtime). Online Mode works fine.
steave
Postby steave » Thu Apr 07, 2011 2:03 pm
anyone? Is there more Info I could provide?
steave
Postby bushman4 » Thu Apr 07, 2011 3:28 pm
What are the folder and file names?
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
