How do I get the Android App to scrobble Last.fm counts
Postby steez » Sun Mar 27, 2011 12:09 am
When I play music through the browser everything scrobbles fine. When I play through the Android app, I am pretty sure it used to scrobble.
(It worked a little weird as it would scrobble everything it downloaded even if it didn't get played.)
Now I am getting no scrobbling through the Android app. Is there anything I can try to get this to work?
Thanks.
Streamed from phone
[3/26/11 11:12:41 AM MDT]   INFO   PlaylistInputStream   admin listening to "Making Up A Changing Mind (2010)/Pretty Lights - Making Up A Changing Mind - 06 - Easy Way Out Original Mix.mp3"
[3/26/11 11:12:41 AM MDT]   DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/lame] [-S] [-h] [--resample] [44.1] [-b] [160] [--tt] [Easy Way Out Original Mix] [--ta] [Pretty Lights] [--tl] [Making Up A Changing Mind] [/media/data/Music/Pretty Lights/Making Up A Changing Mind (2010)/Pretty Lights - Making Up A Changing Mind - 06 - Easy Way Out Original Mix.mp3] [-]
[3/26/11 11:16:16 AM MDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/lame) fatal error: can't update LAME-tag frame!
Streamed from browser
[3/26/11 5:59:13 PM MDT]   INFO   PlaylistInputStream   admin listening to "† (Cross)/1-11 Waters of Nazareth.mp3"
[3/26/11 5:59:13 PM MDT]   DEBUG   AudioScrobblerService   Successfully registered now playing for song 'Waters of Nazareth' for user jeromesteez at Last.fm
steez
Postby baaldemon » Sun Mar 27, 2011 2:39 pm
It stopped scrobbling because you upgraded your server to 4.4. In the 4.4 release the old way of scrobbling was disabled for players that use the REST based api, which the android app uses. The player has yet to be updated to call the new api so that it will scrobble again.
With the new api the scrobbling will be more as you expect it, because the client will be making the choice of what to scroble rather than the server which may or may not know your intentions when grabbing a song.
baaldemon
Postby steez » Mon Mar 28, 2011 5:56 pm
Thanks for the reply.
how about the
can't update LAME-tag frame! - is there anything I can do to prevent seeing that message? or should I start a new thread for that one. :?:
steez
Postby bushman4 » Thu Mar 31, 2011 5:20 pm
The new version of the Android app (available sometime in the last 24 hours...) looks to re-enable the scrobbling from the Android Client.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
