music folder on external hdd attached to Belkin share 300
Postby ellcnlael » Sun Mar 27, 2011 4:36 am
Hello everyone I am trying to set up my subsonic for use by an android phone. I currently have all my music saved on an external hdd that is attached to my belkin share300 router. I have tried to add this folder to subsonic on the laptop that has the helper app installed. but I still get the red message at the top that says folder not found. I HAVE followed the instructions from monroeworld and given subsonic the proper log in and rights but still no help. does anyone have the fix for this. my file path is z:\itunes music\ music
Also I copied a few songs to a folder on desktop and added that folder to subsonic, just to see if the music would be found. This folder was recognized immediately. But a few songs did not show up in subsonic. I noticed that the songs that failed to show says that they are protected when I mouse over the files. is this normal? how can I fix this also?
ellcnlael
Postby bushman4 » Wed Mar 30, 2011 7:06 pm
What is Z: mapped to?
Go to a command prompt (start->Run->CMD<enter>)
Type "Net Use" (no quotes) and hit enter.
In the list there should be a Z:\ and next to it the remote location.
Let's just say it says "\\Server\Music" in the remote location field...
Set your Subsonic music location to "\\Server\Music\itunes music\music"
I bet it will work then.
The problem is that Z:\ is not mapped to that network location for the user account that Subsonic is running under. There are ways to try to make that work with the Z:\ but they are just workarounds. The correct way is to use the full UNC path.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
