Prepare failed.: status=0xFFFFFFFC (IOException)
Postby tclement » Mon Mar 28, 2011 6:44 pm
I can't play videos on my Samsung Fascinate using Subsonic. Does anyone have suggestions or a fix ?
I get the Prepare Failed message.
I also can't play videos using the JWPlayer
I also receive "operation not permitted" when testing ffmpeg (output below)
I can stream my mp3's.
Here is some information about my setup.
Version 4.4 (build 2169) – February 6, 2011
Server jetty-6.1.x, java 1.6.0_24, Mac OS X (46.6 MB / 83.2 MB)
bash-3.2# pwd
/Volumes/My Book/Movies
bash-3.2# /Library/Application\ Support/Subsonic/transcode/ffmpeg -i UP
FFmpeg version SVN-r25203-einsteinx2, Copyright (c) 2000-2010 the FFmpeg developers
built on Sep 26 2010 02:08:29 with gcc 4.2.1 (Apple Inc. build 5664)
configuration: --prefix=/Volumes/Ramdisk/ --as=yasm --extra-version=einsteinx2 --disable-shared --enable-static --disable-ffplay --disable-ffserver --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-libspeex --enable-bzlib --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-nonfree --enable-version3
libavutil 50.28. 0 / 50.28. 0
libavcore 0. 9. 0 / 0. 9. 0
libavcodec 52.90. 0 / 52.90. 0
libavformat 52.78. 5 / 52.78. 5
libavdevice 52. 2. 2 / 52. 2. 2
libavfilter 1.45. 0 / 1.45. 0
libswscale 0.11. 0 / 0.11. 0
libpostproc 51. 2. 0 / 51. 2. 0
UP: Operation not permitted
tclement
Postby GJ51 » Tue Mar 29, 2011 3:50 am
Videos work best if they are preformatted as mp4 or flv. Don't expect miracles over a 3g connection. Your not going to watch the latest Blue ray transcoded by an Atom powered NAS and transmitted over 3g to an Android phone. You can however get results on a par with youtube if you pretranscode your video into flv at a mobile approprate resolution for the phone, and have decent upload speed from the server and reasonably good download speed to the phone. I have watched DVD movies formatted to flv over the phone that actually ran well without buffering and looked pretty good as well. It takes a bit of tinkering and getting a feel for what your harware and connection speeds are capable of.
I've also formatted BlueRay video to mp4 and was able to watch it over FIOS connections on a laptop from about 400 miles from my home. Std. DVD video over a good connection is no problem as long as you have good upload bandwidth and a good download capability at the other end. The same holds for mobile devices with a good Wifi connection. It takes some work, and experimentation to get a feel for where the bottlenecks are and know what's realistic in a given environment.
video not playing throug jwplayer - log excerpt
Postby tclement » Wed Mar 30, 2011 2:48 pm
I don't see any errors in the log. Subsonic finds the file and begins streaming it. However, JWPlayer displays an error
Any thoughts about how to fix this ?
Jwplayer output:
Video not found or access denied: /stream?pathUtf8Hex=2f566f6c756d65732f4d7920426f6f6b2f4d6f766965732f536872656b2d312f536872656b2d312e6d3476&maxBitRate=1000&timeOffset=0&player=4
Log file output:
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/My Book/Movies/Shrek-1/Shrek-1.m4v':
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) major_brand : M4V
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) minor_version : 1
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) compatible_brands: mp42isomavc1M4A M4V
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : HandBrake 0.9.4 2009112300
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 01:26:22.86, start: 0.000000, bitrate: 1046 kb/s
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(und): Video: h264, yuv420p, 640x352 [PAR 321:320 DAR 321:176], 882 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
[3/30/11 9:46:12 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(und): Audio: aac, 48000 Hz, stereo, s16, 159 kb/s
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [buffer @ 0x1100c70] w:640 h:352 pixfmt:yuv420p
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [scale @ 0x1103660] w:640 h:352 fmt:yuv420p -> w:642 h:352 fmt:yuv420p flags:0xc0000004
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.78.5
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0(und): Video: flv, yuv420p, 642x352 [PAR 1:1 DAR 321:176], q=2-31, 1000 kb/s, 1k tbn, 25 tbc
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1(und): Audio: libmp3lame, 44100 Hz, stereo, s16, 64 kb/s
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[3/30/11 9:46:13 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Press [q] to stop encoding
tclement
Postby GJ51 » Wed Mar 30, 2011 2:56 pm
Try:
ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 23.976 -s %wx%h -acodec copy -
Postby tclement » Wed Mar 30, 2011 3:03 pm
Gary, same result using
Using: ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 23.976 -s %wx%h -acodec copy -
[3/30/11 9:59:19 AM CDT] INFO PlaylistInputStream tclement listening to "My Videos/Roger Ingram Wedge Breath Pt. 2 of 2.mpg"
[3/30/11 9:59:19 AM CDT] DEBUG TranscodeInputStream Starting transcoder: [/Library/Application Support/Subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/Volumes/My Book/My Videos/Roger Ingram Wedge Breath Pt. 2 of 2.mpg] [-async] [1] [-b] [1000k] [-s] [640x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) FFmpeg version SVN-r25203-einsteinx2, Copyright (c) 2000-2010 the FFmpeg developers
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) built on Sep 26 2010 02:08:29 with gcc 4.2.1 (Apple Inc. build 5664)
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) configuration: --prefix=/Volumes/Ramdisk/ --as=yasm --extra-version=einsteinx2 --disable-shared --enable-static --disable-ffplay --disable-ffserver --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-libspeex --enable-bzlib --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-nonfree --enable-version3
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavutil 50.28. 0 / 50.28. 0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcore 0. 9. 0 / 0. 9. 0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcodec 52.90. 0 / 52.90. 0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavformat 52.78. 5 / 52.78. 5
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavdevice 52. 2. 2 / 52. 2. 2
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavfilter 1.45. 0 / 1.45. 0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [mpeg @ 0x1809600] max_analyze_duration reached
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Input #0, mpeg, from '/Volumes/My Book/My Videos/Roger Ingram Wedge Breath Pt. 2 of 2.mpg':
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 00:09:08.44, start: 1.000000, bitrate: 6343 kb/s
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], 9000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, 2 channels, s16, 224 kb/s
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [buffer @ 0x11011a0] w:720 h:480 pixfmt:yuv420p
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [scale @ 0x11013c0] w:720 h:480 fmt:yuv420p -> w:640 h:360 fmt:yuv420p flags:0xc0000004
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.78.5
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0: Video: flv, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 1000 kb/s, 1k tbn, 29.97 tbc
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1: Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[3/30/11 9:59:19 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Press [q] to stop encoding
Log output using default transcoder:
[3/30/11 10:01:53 AM CDT] DEBUG TranscodeInputStream Starting transcoder: [/Library/Application Support/Subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/Volumes/My Book/My Videos/Roger Ingram Wedge Breath Pt. 2 of 2.mpg] [-async] [1] [-b] [1000k] [-s] [640x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) FFmpeg version SVN-r25203-einsteinx2, Copyright (c) 2000-2010 the FFmpeg developers
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) built on Sep 26 2010 02:08:29 with gcc 4.2.1 (Apple Inc. build 5664)
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) configuration: --prefix=/Volumes/Ramdisk/ --as=yasm --extra-version=einsteinx2 --disable-shared --enable-static --disable-ffplay --disable-ffserver --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-libspeex --enable-bzlib --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-nonfree --enable-version3
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavutil 50.28. 0 / 50.28. 0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcore 0. 9. 0 / 0. 9. 0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcodec 52.90. 0 / 52.90. 0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavformat 52.78. 5 / 52.78. 5
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavdevice 52. 2. 2 / 52. 2. 2
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavfilter 1.45. 0 / 1.45. 0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [mpeg @ 0x1809600] max_analyze_duration reached
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Input #0, mpeg, from '/Volumes/My Book/My Videos/Roger Ingram Wedge Breath Pt. 2 of 2.mpg':
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 00:09:08.44, start: 1.000000, bitrate: 6343 kb/s
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], 9000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, 2 channels, s16, 224 kb/s
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [buffer @ 0x11011a0] w:720 h:480 pixfmt:yuv420p
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) [scale @ 0x11013c0] w:720 h:480 fmt:yuv420p -> w:640 h:360 fmt:yuv420p flags:0xc0000004
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.78.5
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0: Video: flv, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 1000 kb/s, 1k tbn, 29.97 tbc
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1: Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[3/30/11 10:01:53 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
tclement
Postby tclement » Wed Mar 30, 2011 3:06 pm
hmm, looking closer, it doesn't look like your transcoder suggest too effect. I don't really know how to make it take effect.
I created a new m4v > flv rule and disabled the default one.
Do I need to do something else for the new rule to be used ?
thanks
Tim
tclement
Postby GJ51 » Wed Mar 30, 2011 3:09 pm
Rereading the thread here, are you trying to get this working on the desktop or the phone? Does the file play on the desktop?
Postby tclement » Wed Mar 30, 2011 3:18 pm
videos don't play on the desktop or phone.
I was thinking that I should get it working on the desktop first, then work on the phone.
However, I prefer to play videos on the phone.
tclement
Postby tclement » Wed Mar 30, 2011 3:26 pm
When I use your transcoder command,
From the phone, the results change.
I still get " Prepare failed" , but the status changed to 0x1 (IOException)
I am connecting to subsonic through wifi from my android.
Log file output shows no errors:
[3/30/11 10:22:11 AM CDT] INFO PlaylistInputStream tclement listening to "Babe/Babe.m4v"
tclement
Postby tclement » Wed Mar 30, 2011 3:31 pm
The phone seems to be downloading approx 2MB each time before it displays the Prepare failed.: status=0x1 (IOException) message
tclement
Postby tclement » Wed Mar 30, 2011 3:35 pm
I don't think it is really downloading 2MB.
tclement
Postby tclement » Wed Mar 30, 2011 3:45 pm
Something else I noticed
Comparing playing an mp3 vs an m4v
When I select the m4v from the list and select the green play button,
I get a "playlist empty" message.
When I select an mp3, and select the green play button, it plays.
tclement
Postby GJ51 » Wed Mar 30, 2011 4:09 pm
Let's try getting it working on the local server first. What happens when you open SS on the server and try to play an mv4?
Postby tclement » Fri Apr 01, 2011 8:11 pm
Sorry for the delay.
Regarding playback on the local server. It worked today with no changes on my part. I noticed the following in the log file:
3/30/11 10:59:41 AM CDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) fatal error: can't update LAME-tag frame!
[3/31/11 3:00:00 AM CDT] INFO SearchService Starting to create search index.
[3/31/11 3:00:00 AM CDT] INFO SearchService Created search index with 1000 entries.
[3/31/11 3:00:00 AM CDT] INFO SearchService Created search index with 2000 entries.
[3/31/11 3:00:01 AM CDT] INFO SearchService Created search index with 3000 entries.
[3/31/11 3:00:01 AM CDT] INFO SearchService Created search index with 4000 entries.
[3/31/11 3:00:01 AM CDT] INFO SearchService Created search index with 5000 entries.
[3/31/11 3:00:01 AM CDT] INFO SearchService Created search index with 6000 entries.
[3/31/11 3:00:01 AM CDT] INFO SearchService Created search index with 7000 entries.
[3/31/11 3:00:02 AM CDT] INFO SearchService Created search index with 8000 entries.
[3/31/11 3:00:02 AM CDT] INFO SearchService Created search index with 9000 entries.
[3/31/11 3:00:02 AM CDT] DEBUG SearchService Logically deleting info for album /Volumes/My Book/Movies/Thousands Not Billions. Not found on disk.
[3/31/11 3:00:02 AM CDT] INFO SearchService Updating Lucene search index.
[3/31/11 3:00:03 AM CDT] INFO SearchService Created search index with 9568 entries.
[3/31/11 8:45:26 AM CDT] INFO PodcastService Starting scheduled Podcast refresh.
[3/31/11 8:45:26 AM CDT] INFO PodcastService Completed scheduled Podcast refresh.
[4/1/11 3:00:00 AM CDT] INFO SearchService Starting to create search index.
[4/1/11 3:00:00 AM CDT] INFO SearchService Created search index with 1000 entries.
[4/1/11 3:00:00 AM CDT] INFO SearchService Created search index with 2000 entries.
[4/1/11 3:00:00 AM CDT] INFO SearchService Created search index with 3000 entries.
[4/1/11 3:00:00 AM CDT] INFO SearchService Created search index with 4000 entries.
[4/1/11 3:00:01 AM CDT] INFO SearchService Created search index with 5000 entries.
[4/1/11 3:00:01 AM CDT] INFO SearchService Created search index with 6000 entries.
[4/1/11 3:00:01 AM CDT] INFO SearchService Created search index with 7000 entries.
[4/1/11 3:00:01 AM CDT] INFO SearchService Created search index with 8000 entries.
[4/1/11 3:00:01 AM CDT] INFO SearchService Created search index with 9000 entries.
[4/1/11 3:00:01 AM CDT] INFO SearchService Updating Lucene search index.
[4/1/11 3:00:02 AM CDT] INFO SearchService Created search index with 9568 entries.
[4/1/11 8:45:26 AM CDT] INFO PodcastService Starting scheduled Podcast refresh.
[4/1/11 8:45:26 AM CDT] INFO PodcastService Completed scheduled Podcast refresh.
tclement
Postby tclement » Fri Apr 01, 2011 8:14 pm
Now, when I play a movie from my Android
the following is in the log file
[4/1/11 3:04:12 PM CDT] INFO PlaylistInputStream tclement listening to "Baby Einstein Baby Bach (1999)-1/Baby Einstein Baby Bach (1999)-1.m4v"
However, nothing plays on the Android, I also don't get any errors.
There is text that says "Playlist is empty"
tclement
