Help - Can't see music on Android...
Postby imasterxx » Thu Mar 31, 2011 1:52 am
Hello.
I'm running Windows 7 with Subsonic and I'm trying to stream music to my android phone. I have the Sonic server configured (and tested connectivity "Connection is OK. Server unlicensed" from my android - well within the trial limit). User is configured to play files and all that good stuff. And I can see all my music when I log into the server via Firefox (all the music is listed on the left). But for some reason I can't see any music on my phone. I keep thinking I missed something and continue to look through all the menus and settings but for the life of me I can't figure out what is wrong. Note: All my music is in a single folder (not sure if this is an issue). I skimmed through the tutorial but didn't see anything pertaining to my problem. I have about 2100 songs in the folder. I don't believe router settings are an issue because I've tested connectivity (successfully) from the phone. I'm stumped. Any help is appreciated.
Oh, And I've already tried the Update search index a couple times.
Update: I still can't see anything in my music library (on the phone), but when I search for part of a song I do see it come up. Sometimes it plays and sometimes it doesn't when I click on it (I think that's a different issue all together). But its strange that I can search for a song but I don't see it in the main library section. Shouldn't I be able to see all my songs I have in the folder in that library? When I click on Shuffle Play from the home screen it doesn't shuffle all my songs. Instead it seems like it only shuffles the ones that I searched for already.
Thanks.
imasterxx
Postby GJ51 » Thu Mar 31, 2011 3:09 am
All the music in one folder is the problem. Subsonic organizes the music best when it's organized into X:\Music\Artist\Album\tracks folders. Create a new folder and place an Album in it to see if it fixes the problem. You can still maintain your current format, just create a new folder within the current folder and move the music down one level. I have many single tracks stored this way, i.e. X:\music\singles\tracks.
Listen to it. :wink:
Postby -Airwave- » Thu Mar 31, 2011 3:31 am
quick way
install itunes, add music, consolidate library, point ss to the itunes folder in your music folder
-Airwave-
Postby imasterxx » Thu Mar 31, 2011 11:21 am
I'll give it a shot. Thx
imasterxx
Postby fdullemond » Thu Mar 31, 2011 12:19 pm
Well, that is exactly the problem.....
The android client only shows files in a subdirectory under the music root...
Just move all (or a couple) files into a subdirectory directly under your music root directory and they will pop up in android...
fdullemond
Postby imasterxx » Thu Mar 31, 2011 12:41 pm
yea that fixed it. i guess i didn't think it would be an issue to have everything in the root directory (especially since it all came up in the web console) but its no big deal.
thanks all!
imasterxx
